Spider Cracks In Garage Foundation And Concrete Ramp Up Into Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-29-2010, 10:30 AM   #1
spider cracks in garage foundation and concrete ramp up into garage
will concrete sealant stop existing spider cracks from spreading and getting wider. this driveway and garage are only 3 months old
alhippy is offline   Reply With Quote
Old 08-29-2010, 10:48 AM   #2
Licensed Engineer
Rewards Points: 175
Unfortunately, No. It sounds as if the installing contractor poured the concrete on a very hot day with no provisions to prevent shrinkage cracks.
Provisions against shrinkage cracks include: placing a vapor barrier (plastic)on top of the concrete to prevent excessively rapid drying and keeping this membrane wet; installing a double coating of surface sealer while the concrete is curing; saw cutting the control joints within a few hours rather than the next day; pouring in the early morning; buying a special concrete mix to prevent rapid drying; etc.
There are a lot of things which can be done to avoid shrinkage cracking, which is what I think you have since you call them spider web cracks. Your only solution now is to make the contractor break it out and re-pour the entire slab.
MI-Roger is offline   Reply With Quote
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 09:37 PM
Replacement concrete garage floor, dowelled into foundation? Niffumdutz Building & Construction 5 02-19-2010 08:31 PM
Basement Garage with Concrete Slab: To Vent or not to Vent N-GA-Homeowner Remodeling 3 05-29-2009 06:13 AM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 10:51 PM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 12:32 AM
