Spf Framing Vs. Engeneered Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-28-2011, 10:44 AM   #1
spf framing vs. engeneered framing
(building a 30 foot deep garage...)
Okay, attaching a spf roof joist and spf ceiling joist is pretty straight foward with birds mouth cuts and being nailed into the spf ceiling joist, but since I plan on spaning 30 feet, engeneered floor/ceiling joist seem to be a better plan, but how is the spf roof joist attahced to the engeneered ceiling joist?!
Metal pieces?
fill the center of the engeneered joist with ply for nailing?
Brent
bthomas67wagon is offline   Reply With Quote
Old 03-29-2011, 12:33 AM   #2
Registered User
Rewards Points: 4,924
Run it by your local B.D., ply may work; http://www.ilevel.com/literature/TJ-4000.pdf
Remember the nailing, last Table, bottom of page, don’t forget the pitch adjustment factor below that; http://publicecodes.citation.com/ico...002_par023.htm
Gary
pocket hole jointery and cabinet screws for framing newbymodeler Carpentry 29 03-07-2013 04:17 PM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 02:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 10:27 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
