Special Door Required? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-10-2010, 11:06 PM   #1
Special door required?
I purchased a house with an unfinished 2nd floor. In one of the rooms I am putting in a closet door to the attic space (to have access to everything behind the walls. When I got my rough framing inspection done, the guy mentioned something about an "R19" door.
I asked around and nobody has ever heard of this. If I have a doorway to attic space (not a insulated closet), do I need a special door, or can I get a basic pre-hung hallow-core door from home depot?
docmattman is offline   Reply With Quote
Old 05-10-2010, 11:09 PM   #2
Is the attic area fireblocked ?
If its a wide open area I'd install a solid door to slow down any possible fire
A solid door will also keep the cold out
Never heard of an R19 door
Old 05-10-2010, 11:10 PM   #3
Just call me Andrew
Rewards Points: 1,020
Maybe it's some sort of insulated door? R-value maybe?
Andrew
secutanudu is offline   Reply With Quote
Old 05-10-2010, 11:19 PM   #4
I'm not sure if it's fireblocked. It's not a huge open space.
I was planning on getting the basic prehung door and just adding weather stripping to it. Would this pass by coding standards?
Old 05-11-2010, 10:04 PM   #5
That link doesn't work.
So do you think I could just use a hallow-core door and put the foam board and firestop on the attic side or would it need to be a solid door?
Old 05-11-2010, 10:06 PM   #6
Registered User
Rewards Points: 4,924
R-19 is what is required on your room/attic walls for your locale. Weatherstrip and attach rigid foam board to the attic side, cover with material (fire-stopping over rigid foam) if required in your locale.
Ask the Inspector
, many people don't understand heat loss and R-values.
Be safe, Gary
Old 05-11-2010, 10:09 PM   #7
Registered User
If you have heating/cooling units, it may need solid core- ask the inspector or check their on-line web site like this: http://www.cityofsacramento.org/dsd/...quirements.pdf
Most city/county have them.
Be safe, Gary
Old 05-11-2010, 10:43 PM   #8
Rewards Points: 1,910
Generally speaking the best way to figure out what an inspector means when it's not clear is to................................................ .........................................ASK HIM
Old 05-12-2010, 08:33 AM   #9
R-19 insulation in figerglass is typically for 2X6 construction. And since the doorway leads to an unconditioned space, you should use an exterior door, to seal that area as if it were the outside.
Is the doorway constructed with 2X6s or 2X4s? The door jamb sizes are different, obviously, for those two sizes...that may may been his lingo, referring to a pre-hung exterior door for 2X6 construction.
RoyalAcresRod is offline   Reply With Quote
Old 05-12-2010, 10:06 AM   #10
It's 2x4 construction.
Old 05-12-2010, 10:12 AM   #11
In that case I'd just buy and install a pre-hung exterior door in the style of your choice. Probably ought to be able to find one for close to $100. BTW, those composite shims make the job much easier, IMO.
It's real easy to just hit 'em with a hammer, and they snap off flush...saves having to cut or score repeatedly the wood shims...they're definitely worth the extra dollar or so.
Shy away from special order shingles? Tranch Roofing/Siding 1 07-20-2009 12:16 PM
Anything special for attaching drywall to the ceiling? tripower Drywall & Plaster 4 06-29-2009 09:29 AM
Should I get this Air Compressor/Tool combo on special? pure_energy1 Tools 4 05-12-2009 08:46 PM
Is ceiling paint special? SR996 Painting 2 03-27-2009 05:51 PM
Special Spray for Roof Exhaust Vent's? amdspitfire Roofing/Siding 3 12-26-2008 11:46 AM
