#1 |
Span For Flooring / Ceiling
I want to use 2X8 T&G Cyprus for an exposed ceiling and a finished floor on the other side. Whats the longest span I can go without any support? I'm hoping for 6' feet.
Thanks in advance |
#2 |
Presuming that you are putting these flooring boards together tongue and groove unless I am thinking wrong you normally are going to be running and attaching these boards either perpendicular or diagonally over joists.
there is no way you are going to be allowed to go 6 foot I am thinking the joists will be set at 16" o.c. or maybe 24" o.c. at the most.I am sure an actual builder or inspector may chime in here at some point with more information...... |
#3 |
A six foot span for flooring? Not going to happen. Are the "whatevers" that you are going to put the T&G over sitting there 6' apart? What are they, and what are they holding up now? I'm confused. j
#4 |
Moderator
No, this will get you started: page #195: http://books.google.com/books?id=idB...floors&f=false
Be safe, Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#5 |
thnaks for the replies so far. The flooring will sit on exposed 4X4's and like I said, I was hoping to get a six foot span between them. That doesnt look like its going to happen. The 2X8 cyprus is a lot stronger than any type of pine flooring. The T&G glued makes for a pretty solid floor but now Im hoping to be allowed a 2 foot span. Its all good. The exposed lumber is a great look for what I want to do.
| Display Modes | |
| Old ceiling replacement | idsp | General Discussion | 12 | 07-25-2009 11:48 AM |
| Advice for installing ceiling fan | Ceiling Fan Man | Electrical | 5 | 06-02-2009 05:18 PM |
| A 2x6 to span 21' as a ceiling joist??? | Scuba_Dave | Building & Construction | 2 | 03-01-2009 02:58 PM |
| 9 foot span ok for metal studs as ceiling joists? | Garasaki | Carpentry | 7 | 08-22-2008 10:12 AM |
| Pot lights in a drop ceiling | Howdy | Electrical | 3 | 03-14-2008 09:23 PM |
