Spalling Concrete. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-02-2011, 12:47 PM   #1
spalling concrete.
I have a retaining wall that is spalling that I want to fix. I have been told that once this situation starts, it gets worse pretty quickly. What can I use to fix this? Is it very hard to work with, or can a first timer make it look pretty even?.
teamcampreder is offline   Reply With Quote
Old 08-02-2011, 12:59 PM   #2
concretemasonry's Avatar
Rewards Points: 2,594
That is some ugly, very poor and older concrete that is falling apart quickly now. It should be replaced with something appropriate, or if you are selling, patch it, make it look good and move quickly.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
teamcampreder (08-03-2011)
Old 08-02-2011, 01:03 PM   #3
Do you have a reccomended product to patch over it?
Old 08-02-2011, 01:06 PM   #4
Concrete & Masonry
Rewards Points: 548
That's well beyond spalling, that's typically what we would call "rotten" concrete. Any patch over rotten concrete will likely fail within a year or so.
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Old 08-02-2011, 01:23 PM   #5
crap.
so I should really replace the whole wall? Do you have any idea what something like that would cost? I assume its something I cant do myself.
Old 08-02-2011, 01:27 PM   #6
Rewards Points: 150
The problem is there is no way to add structural integrity to that wall with any kind of overlay and your wall is failing structurally.
You can absolutely do it yourself. This is a DIY forum after all. What is behind the wall/on top of the dirt behind the wall?
Broughton is offline   Reply With Quote
The Following User Says Thank You to Broughton For This Useful Post:
Old 08-02-2011, 01:30 PM   #7
I will take more pictures, but there is about a 3 feet of garden (which we don't care to keep if it means its easier), and then it butts up against the foundation of the home.
Old 08-02-2011, 01:34 PM   #8
Rewards Points: 150
That is trickier. The force that the house exerts on the ground around it extends from the foundation at a 45 degree angle into the earth around it. Would that angle of force cut through the failing wall in your case?
Old 08-02-2011, 01:49 PM   #9
I will grab my protractor and sexton lol jk. Yes, I am 99% positive that it would.
Old 08-02-2011, 02:09 PM   #10
Rewards Points: 150
Well, since the wall is supporting the dirt that is supporting your house, you may need to underpin the house before removing the wall. Can you build a new wall in front of the old one in that strip of grass at the base?
Old 08-02-2011, 02:15 PM   #11
joed's Avatar
Rewards Points: 12,458
Is the wall lower than the footing of the house? It is only holding up the house if it lower than the footing. If it is just holding up dirt against the upper foundation no need to worry about the house.
The Following 2 Users Say Thank You to joed For This Useful Post:
concretemasonry (08-02-2011), teamcampreder (08-03-2011)
Old 08-02-2011, 02:34 PM   #12
Will Report back when I get home w/ more pics
Old 08-02-2011, 07:39 PM   #13
See Below: The Wall almost goes to the bottom of the foundation, but not quite, because the sidewalk is on a hill going down. I have a basement garage, so use that as a frame reference for the bottom of the foundation.
Old 08-02-2011, 10:18 PM   #14
Rewards Points: 150
Oh if you have a basement then you are good to go! That wall is only supporting the dirt behind it. Have you ever done any concrete before?
Old 08-03-2011, 07:29 AM   #15
joed's Avatar
Looks to me like you could even just remove it and landscape the area.
The Following User Says Thank You to joed For This Useful Post:
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
House Main Drain Leaking under Concrete Tom738 Plumbing 0 06-01-2010 07:54 AM
