Old 04-16-2011, 06:30 PM   #1
GBunny
Spacing under doors & air pressure
I had new doors installed in the basement. The contractor had a heck of a time levelling the doors since he said the wall frames were over an inch out. He didn't fix the wall frame, he just removed drywall at the bottom of the door frame and added extra wood at the top. It looks ugly but the door is straight. Not quite sure if this was the correct was to attack it.
The bathroom door has maybe a 1/4" gap under it. The bottom of the furnace door is crooked - maybe 1/2" on one side and 1/4" on the other. Is this ok? I don't want to have to fix the entire wall.
Is it normal for the walls to get so out of whack?
GBunny is offline   Reply With Quote
Old 04-16-2011, 07:12 PM   #2
Moderator
kwikfishron's Avatar
The doors have to be installed plumb and square to work properly. It sounds like he did that.
Most of the ugly should go away with trim but if the walls and floor is that far out something is going to show somewhere.
Post some pictures if you can to get the best responses.
You lost me on the air pressure thing.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 04-17-2011, 12:37 AM   #3
Moderator
If a forced-air furnace, the 3/4-1" gap under the door serves as the return air path, I believe......
Gary
Clothes taking longer to dry?
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 10:03 PM
Home's Pressure valvue and sprinkler steve0617 Landscaping & Lawn Care 2 01-04-2011 02:37 PM
Hydronic boiler pressure question. RickInMissouri HVAC 1 01-23-2010 05:57 AM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 01:59 PM
