Spacing For Screwing Subfloor. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-05-2008, 12:15 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
Spacing for screwing subfloor.
I'll be screwing and gluing a subfloor. What is the spacing of the subfloor. I'm guessing it's 6" around the perimeter and 10" in the field. Is that correct? Also, Is a 2-2 1/4" screw adequate?
Does anyone nail subfloors anymore?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 10-05-2008, 12:27 PM   #2
Only if you like squeaks.
Marvin Gardens is offline   Reply With Quote
Old 10-05-2008, 04:27 PM   #3
the Musigician
DangerMouse's Avatar
now hold on there, using the RIGHT nails will not result in squeaks. my floors are nailed, and i never had one squeak. but do not use smooth nails, of course. they will pull up and *presto* mousefloors. but what do i know? i'm just a mouse.
DM
Old 10-05-2008, 09:04 PM   #4
I have gas!
I can only find the code requirements for nails in the MA building code. I guess I'll have to give them a ring tomorrow.
Edit: 6/12 per manufacturer.
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
Replaced section of subfloor but it's 1/16" higher. Is that a prob? Piedmont Carpentry 1 08-29-2008 10:12 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 07:39 AM
BAthroom Subfloor Blaze25 Flooring 3 11-17-2006 09:06 AM
