Old 08-13-2005, 09:55 AM   #1
Spacing of joists
I want to fit a platerboard ceiling onto false joists in a kitchen, the false joists are secure to the original joists. The spacing of the joists does not match a full sheet of plasterboard, do i need to cut the full sheets so they meet on the joists, or can i have joints of the plasterboard between the joists ??
christofish is offline   Reply With Quote
Old 08-17-2005, 01:16 PM   #2
Spacing of joists
Hi
It is always better to have the seems of plasterboard on a support. I have seen it that the installer as put a floating (only supported by the drywall) board at the edge seam of it. (generally that area will show a crack due to some flex) any way you best bet will probably be to cut the length of the drywall to meat you joists and leave the sides (finished edge) uncut.
Mgmopar
MgMopar is offline   Reply With Quote
Old 08-17-2005, 02:04 PM   #3
Spacing of joists
that all makes sense, many thanks
