Spacing On Gate Pickets - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-19-2012, 11:36 AM   #1
spacing on gate pickets
what is the code?
Ed Heinemann is offline   Reply With Quote
Old 09-19-2012, 12:12 PM   #2
Rewards Points: 2,210
Where re you located? That makes a difference.
Here there is no code for a gate that is on the ground, a deck gate or a stair case gate is different.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
gregzoll (09-19-2012)
Old 09-19-2012, 01:05 PM   #3
Rewards Points: 704
Originally Posted by Ed Heinemann View Post
what is the code?
I believe the code is 4" but code or no code for once let common sense prevail and place them no farther apart than 4" so a small child has no chance of injury or worse. If it were my project I'd probably go with 3-1/2" spacing.
SeniorSitizen is offline   Reply With Quote
Old 09-19-2012, 08:41 PM   #4
Rewards Points: 6,652
what is the code?
The Moon rises from the East, while the Lion sleeps.
The Following User Says Thank You to gregzoll For This Useful Post:
mae-ling (09-19-2012)
Old 09-20-2012, 09:28 AM   #5
DIY-er
The code here is 4 inches, small enough so a baby cannot crawl through
KevinPh is offline   Reply With Quote
Old 09-20-2012, 11:15 AM   #6
Kevin - That is for stair railings/gates. Not for yard Gates as I understand it.
Old 09-20-2012, 12:58 PM   #7
Usually for fences, it is one board spacing, so that it appears consistent when looking at it. More for visual than anything else.
Old 09-20-2012, 02:29 PM   #8
DIY-er
You're right, Mae-Ling, it is for railings, anywhere there is a drop of 2 ft or more. I've not heard of a building code requirement for a gate where there is no fall hazard - it could be 1 inch or 3 ft, depending on how you want it to look.
attaching redwood gate to block wall titan7 Concrete, Stone & Masonry 4 08-27-2012 12:53 AM
Need to ID Gate Valve (Please Help) MikeGV Plumbing 3 10-04-2010 12:02 PM
Gate Design Question rocknroll99 Building & Construction 5 04-13-2010 08:46 AM
Driveway Gate Construction Questions KP Texan Building & Construction 3 07-30-2009 09:45 PM
