Spacing Of Floor To Ceiling Column Jacks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-02-2011, 09:41 PM   #1
Post
Spacing of Floor to Ceiling Column Jacks
I removed two walls that made up a hallway between two separate bedrooms to make one big master bedroom. One of the walls to the large room is a load bearing wall, so I have a couple of column jacks to put into place to brace up the roof. How far apart do I place the columns on a opening that is about 14 ft. long? The house is a detached split level with a pitched roof and after checking I did find a structural beam in the basement approximately under the one large bedroom wall.
Thanks Bruce
bespencer1125 is offline   Reply With Quote
Old 07-02-2011, 10:36 PM   #2
Experienced
Jackofall1's Avatar
Welcome bespencer1125, to the best darn DIY'r site on the web.
Spacing of floor jacks, hmmmm, you already removed the wall, and now you are considering the structural implecations.
Without knowing all the dynamics involved I don't believe anyone here can truly answer your question without misguidance. There are many questions to ask, such as, style of roof, is it a single story, is there a beam under the center line of the posts.
By removing the wal you basically went from a uniform load distribution system to a point load scenario.
Personally I would have an engineer have a look and make recommendations.
Mark
Old 07-03-2011, 01:50 AM   #3
Thanks Mark I have added some information maybe it will help.
Old 07-03-2011, 07:14 AM   #4
Rewards Points: 5,336
Not enough to help with the issue. Someone would need to see what you did, look at the structure and come up with a compensating support system.
Generally, you put the support system in place before you start removing walls.
Why would you do it this way and compromise the houses structural integrity?
Ron
B. Franklin 1759
Old 07-03-2011, 07:20 AM   #5
Not so new
12penny's Avatar
Rewards Points: 520
Good one....you have your cart before the horse.
As Jack said, an engineer or experienced contractor should be your next call. Its imperitive that beams are sized correctly and that point loads carry the weight to the foundation. I know this a DIY site but this must be done correctly.
12penny is offline   Reply With Quote
Old 07-03-2011, 09:59 PM   #6
Thanks I will follow your suggestions
Tags
bracing up ceiling , wall to ceiling jacks
peeled ceiling paint off, how to fix? philosophical Painting 3 10-19-2010 05:28 PM
replacing a 7'6" ceiling for a Split-foyer home czellerhoff Building & Construction 1 10-16-2010 12:36 PM
Popcorn Ceiling Repair CecszaR Painting 7 08-28-2009 04:37 AM
Dark color & downlighting to reduce ugly ceiling in downtown loft bathroom? fredonian Painting 3 08-17-2009 10:20 AM
Spacing of ceiling joists Pineconeman Building & Construction 3 05-14-2005 12:16 AM
