Spacing Drywall Out 1/2" - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-06-2013, 10:43 AM   #1
Rewards Points: 12
Hello,
My question is about how to space my drywall off the existing lathes by 1/2"? Can I use strips of 1/2" drywall over each stud? Do I need to use plywood instead?
The reason I need to is there was plaster and paneling on the walls before. This stuck off the lathes by over 1/2". The existing windows were put in so that the panelling just covered the back edge. If I use just 1/2" drywall over the lathes you would see a gap on the back of the windows.
Thanks in advance!
mtcellar is offline   Reply With Quote
Old 05-06-2013, 12:13 PM   #2
Rewards Points: 256
I would be more likely to use 1/2" plywood in 3" wide strips over the studs. My hesitation in using strips of drywall is the crumbling and breaking over time with all those screws through a narrow piece.
moneymgmt is offline   Reply With Quote
The Following User Says Thank You to moneymgmt For This Useful Post:
woodworkbykirk (11-22-2013)
Old 05-06-2013, 12:48 PM   #3
Rewards Points: 12
Moneymgmt,
Thanks for the reply!
I would agree with your crumbling concern. I think I will use 1/2" plywood strips instead.
Old 05-06-2013, 02:09 PM   #4
I'm going to do something similar soon and I was thinking of gluing strips of drywall together. Too bad you decided on plywood. I would have liked to see how well the drywall worked. Gluing two strips of 1/4" drywall together might make them stonger then one 1/2" strip. For me, I may glue three 1/2" strips together. I'm not sure what glue to use though. I haven't found any information on what happens when you try drilling through construction adhesive but the fact that it's flexible could be a problem.
Dorado is offline   Reply With Quote
Old 05-06-2013, 03:31 PM   #5
Rewards Points: 256
In your house do what you want! I am struggling to see what you hope to gain by the added expense and time? You must be retired
Old 05-06-2013, 03:36 PM   #6
I actually look for ways to use up left over building materials. I have half a tube of construction adhesive to use up before it goes bad. And I'd like to keep it fireproof if I could.
Old 05-06-2013, 07:39 PM   #7
Roofmaster
Rewards Points: 2,172
Why don't you just pack out the trim? Unless I'm missing something. I do better with pictures.
Old 05-06-2013, 09:54 PM   #8
Too Short? Cut it Again!
I would rip some fir strips from 2x on your table saw to the exact thickness you want. Seems less expensive than cutting up plywood or MDF? Some on this site suggest sistering 2x out to the the correct height but seems like a lot of material waste. Would be quick though.
Old 05-07-2013, 07:26 AM   #9
If it's down to the studs I would just hang the drywall and fab some trim for the window it's the easiest thing to do with out having to put alot of extra time in to the project.
nightriderrv is offline   Reply With Quote
Old 05-07-2013, 07:46 AM   #10
All the electrical boxes will be to far out though.
Old 05-07-2013, 08:48 AM   #11
Roofmaster
So just move them back, whats the big deal?
Again, why cant they just pack out the trim?
Old 05-07-2013, 09:23 AM   #12
No big deal, just has to be done or they will be sticking out too far. They may not survive moving if they are plastic boxes so it is an extra cost.
Trimming around boxes sticking out 1/2" would look goofy? I assume you were not suggesting to do so though.
The Following User Says Thank You to user1007 For This Useful Post:
Old 05-07-2013, 10:48 PM   #13
all you are doing is essentially shimming drywall. you can use anything 1/2'' thick I use drywall all the time. no different than hanging 2 layers of board
ubcguy89 is offline   Reply With Quote
The Following User Says Thank You to ubcguy89 For This Useful Post:
mae-ling (05-08-2013)
Old 05-08-2013, 10:55 AM   #14
Rewards Points: 81
You could just buy 1/2" sound channel, thats what it is made for.
one cut is offline   Reply With Quote
Old 05-08-2013, 07:07 PM   #15
Not a bad idea. Rather pricey for shim/firring out a wall though.
Tags
drywall , plywood , spacing
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 08:08 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 05:37 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
