Old 05-08-2005, 01:45 PM   #1
Spacing of ceiling joists
Drywalling my garage for conversion into recording/rehearsal studio, however, the ceiling joists are 48" apart. Tried, but found it impossible to add new joists acress the 20' ceiling due to the existing frame. I've read that the joists should be at most 24: apart to hang drywall. My question is, is the 24" guideline for the weight of the drywall on the joists, or more for the support of the drywall itself, (i.e. to keep it from buckling in the middle.) I was thinking we could attach wood between the joists crosswise to add support for the drywall. Will this add too much weight on the joists? Any help in this matter will be greatly appreciated. Thanks!
Pineconeman is offline   Reply With Quote
Old 05-13-2005, 09:34 AM   #2
aka:awesomedell
Send a message via MSN to housedocs
Hello & welcome aboard!
Sorry for the delayed response, most of us are really busy this time of yr. Without knowing a bit more I can't give you a totally a definitive answer, but you may well be able to deal with this in the manner you've suggested.
What size are the existing joists? The drywall will definitely sag between joists on 48" centers, got to bring that down to 24" max and with that you'll have to use 5/8" board on the ceiling to prevent sagging.
All you need is ignorance and confidence and success is assured. - Mark Twain
housedocs is offline   Reply With Quote
Old 05-13-2005, 09:09 PM   #3
Got some joist hangers, and ready to go at it!
Thanks for the reply.
Old 05-14-2005, 12:16 AM   #4
aka:awesomedell
Or here's another thought, if you've got the head space to spare. You could attach 2"x4" furring across the existing joists on 16" centers, lay them flat & you'll have plenty of room to attach the ends of the board and you'll only loose about an 1-1/2" of headroom in the garage, probably not even noticable. Also alot less cutting than using the hangers and putting them in between the existing joists.
Good luck!
More On This Topic
Hi, this is Jon and in this clip we will be installing our fixture box. Now, with the can light that we pulled out, the diameter is about six inches. However, the diameter for our mounting plate is only about four inches. Now, because our opening is so... Read More »
Ceilings in an older house can be unsightly. A relatively inexpensive way to solve the problem is to install ceiling tile. While you can attach ceiling tile directly to the ceiling with glue, it's easier to install furring strips and attach the ceiling... Read More »
What is an I-Joist?
What is an I-Joist? by Expert Village
This is Ben Ingham with Expert Village talking about a walk out basement. Once we get this wall corrected whatever problems and however we can go about getting it corrected and then the next step in the next procedure is to be sure it is reinforce and it... Read More »
Remodeling, whether it is in the garage or in the house is a huge undertaking. One of the easiest projects is building a non-bearing interior wall. The tools are basic, as are the needed carpentry skills. The condition of the floor and ceiling will... Read More »
Building a wine cellar is a terrific way to increase the value of your home while adding an elegant touch to a room or area. Some homeowners choose to build wine cellars off their living rooms. Others might put a wine cellar in a kitchen pantry. No... Read More »
garage ceiling joists josh123 Carpentry 6 07-15-2009 12:07 AM
Necessary to insulate basement ceiling between joists? yummy mummy Building & Construction 12 02-07-2009 12:19 AM
sistering 2x6 ceiling joists nelsonC Building & Construction 23 11-21-2008 11:01 AM
Question about ceiling joists in a garage allpraisebob Carpentry 11 12-14-2006 09:00 AM
Question about ceiling joists... StlJoe Building & Construction 5 12-06-2005 12:52 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
