Old 09-30-2010, 01:17 PM   #1
Space between floors
My house is two stories. I just noticed that there is insulation at the ceiling of the first floor. But there is a gap between that insulation and the up stairs floor. I researched a little bit it seems that it's considered unnecessary to add insulation between floors, because it's like insulating interior walls. But the issue is that the space between first and second floor isn't really air tight, there is one part that's not sealed and opens to the attic (the second floor is in the attic). And even though I can seal this part, there is also the path for the ducts for the first floor AC and heating, which can be hard to seal. What's the common practice in this situation?
deerhunter is offline   Reply With Quote
Old 10-01-2010, 12:45 PM   #2
Gaps ,especially vertical openings between floors should be sealed. In case of fire,these gaps will be used as a way for the fire to spread through out the house.
Ron
Old 10-01-2010, 01:33 PM   #3
Insulation between floors is usually installed to reduce the transmission of sound. Interior walls are sometimes insulated for this reason, also.
When I built my house, I framed the bathroom walls with off-set studs and wove batt insulation in and out to reduce bathroom noise.
It seemed to have been effective!
Old 10-01-2010, 01:40 PM   #4
Xtreme DIY'r
My house has R25 in the 1st floor ceiling
Keeps the 1st floor warm, & allows enough heat to the 2nd floor
Since its one zone & the 2nd floor is bedrooms its a nice way to save on heating cost
I did seal the gaps in the wet wall between basement & 1st floor, 1st floor & 2nd floor
Old 10-01-2010, 09:56 PM   #5
I think I should at least seal that space between floor and ceiling. I plan to seal the flex duct path with sheet metal with holes cut out so that the duct can go through. Then tape the edge with foil tape. It's just that spot is pretty hart to reach.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Bad smell in crawl space. John_W General Discussion 28 10-20-2011 11:24 AM
Dramatically uneven floors mf1963 Flooring 20 09-24-2010 07:35 AM
Estimating CRAWL SPACE Excavation/floor support dwtjan Flooring 1 10-05-2009 07:52 AM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 09:15 PM
