Space Between Basement Wall & Stud Wall ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-23-2009, 09:11 PM   #1
Space between basement wall & stud wall ?
Hi, I'm Lovi, starting to build a basement and want to any how much space is needed betwwen concrete wall and framing. Is there any vapour barrier needed and what kind ? Thank you.
lovi is offline   Reply With Quote
Old 12-24-2009, 07:27 AM   #2
ccarlisle's Avatar
Depends on where you live...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Leaking Basement Wall MStocks Building & Construction 3 10-29-2009 09:57 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-05-2009 11:02 PM
Need unbiased help on finishing basement - Dry wall or panel system? mmr1234 Building & Construction 6 08-29-2009 10:30 AM
Building a 1/2 wall in a basement? BowDown Building & Construction 1 07-27-2009 02:13 PM
