Old 08-01-2008, 03:51 PM   #1
South FL Building Codes
Does anyone do any work in South Florida? I am building a Pergola and would like to know how deep to cement the posts into the ground to comply with Hurricane ordinance. I'm planning on going 4' down with about 4-6" of gravel at the bottom.
Please let me know, if you know!
Matty16 is offline   Reply With Quote
Old 08-01-2008, 05:06 PM   #2
concretemasonry's Avatar
Check with your local code officials. they must have some acceptable standards because of the local concerns for projectiles during hurricanes and tornadoes. It would be a shame for your pergola become a weapon.
Dick
concretemasonry is offline   Reply With Quote
Old 08-01-2008, 05:18 PM   #3
Yep, check with the bldg dept. In Mich for every 2 ft above ground you have to have 1 ft in ground. We have an 9ft Pergola with 6X6'S for supports & about 4 ft (+) in the ground. The city comes and measures the depth before you put the posts in too!! We packed it with small pea gravel for 3 feet or so and soil at the top so the pressure treated lumber has some below ground drainage around it. There are 2 swings on it and it isn't goin anywhere! Been up since 1996 and thru a few Mich wind storms, ice, snow etc. Just my experience with our Pergola.
agrace is offline   Reply With Quote
Old 08-02-2008, 10:11 AM   #4
You will have more than how deep to set your posts to be concerned with it you are in the HVWZ in S FL. straps / hangers / tie-downs
Hire a structural engr, they might be able to design this so it doesn't look like an erecktor set. Shouldn't be more than $ 300- $ 500. Some will even walk this thru the permitting process for you.
do this with out a permit and they may make you take it down. ( don't comply with your red tag?)
They can kill the power to your house...
Big Bob is offline   Reply With Quote
Old 08-02-2008, 10:30 AM   #5
Framing Contractor
You can get the answer as soon as you call your code official.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-02-2008, 11:52 AM   #6
It was a dark and stormy
Yoyizit's Avatar
FYI, for a nominal 4x4'" post in an 8" dia. hole, I figure 1 cu. ft. of concrete is needed for each 45" of depth.
Old 08-02-2008, 12:58 PM   #7
Framing Contractor
You're in Maryland, he's in Florida. He has to follow his codes.
Joe Carola
Old 08-02-2008, 01:41 PM   #8
Yoyizit's Avatar
I wasn't clear. This is a general formula for figuring the space between "square pegs in round holes" if he needed it and if the local codes allow him to sink posts in this way.
Old 08-03-2008, 07:25 AM   #9
http://www.floridabuilding.org/BCISOld/bc/default.asp
have fun
NEC uses building size?????? hhiibel Electrical 14 08-08-2008 01:19 PM
Where to find building codes? nimblemotors General Discussion 5 06-27-2008 08:15 AM
Building codes? Keener General Discussion 2 11-10-2007 08:05 PM
A steel building that doesn't look like a steel building? MMW Building & Construction 1 06-11-2007 05:24 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
