-   -   South FL Building Codes (http://www.diychatroom.com/f19/south-fl-building-codes-24591/)
Matty16 08-01-2008 02:51 PM
Does anyone do any work in South Florida? I am building a Pergola and would like to know how deep to cement the posts into the ground to comply with Hurricane ordinance. I'm planning on going 4' down with about 4-6" of gravel at the bottom.
Please let me know, if you know!
concretemasonry 08-01-2008 04:06 PM
Check with your local code officials. they must have some acceptable standards because of the local concerns for projectiles during hurricanes and tornadoes. It would be a shame for your pergola become a weapon.
Dick
agrace 08-01-2008 04:18 PM
Depth
Yep, check with the bldg dept. In Mich for every 2 ft above ground you have to have 1 ft in ground. We have an 9ft Pergola with 6X6'S for supports & about 4 ft (+) in the ground. The city comes and measures the depth before you put the posts in too!! We packed it with small pea gravel for 3 feet or so and soil at the top so the pressure treated lumber has some below ground drainage around it. There are 2 swings on it and it isn't goin anywhere! Been up since 1996 and thru a few Mich wind storms, ice, snow etc. Just my experience with our Pergola.:)
Big Bob 08-02-2008 09:11 AM
You will have more than how deep to set your posts to be concerned with it you are in the HVWZ in S FL. straps / hangers / tie-downs
Hire a structural engr, they might be able to design this so it doesn't look like an erecktor set. Shouldn't be more than $ 300- $ 500. Some will even walk this thru the permitting process for you.
do this with out a permit and they may make you take it down. ( don't comply with your red tag?)
They can kill the power to your house...
Joe Carola 08-02-2008 09:30 AM
You can get the answer as soon as you call your code official.
Yoyizit 08-02-2008 10:52 AM
FYI, for a nominal 4x4'" post in an 8" dia. hole, I figure 1 cu. ft. of concrete is needed for each 45" of depth.
Joe Carola 08-02-2008 11:58 AM
You're in Maryland, he's in Florida. He has to follow his codes.
Yoyizit 08-02-2008 12:41 PM
I wasn't clear. This is a general formula for figuring the space between "square pegs in round holes" if he needed it and if the local codes allow him to sink posts in this way.
:huh:
Big Bob 08-03-2008 06:25 AM
http://www.floridabuilding.org/BCISOld/bc/default.asp
have fun
