Soundproofing Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-21-2012, 10:27 AM   #1
Rewards Points: 150
Soundproofing windows
http://www.menards.com/main/paint/dr...842-c-7944.htm
Does anyone know if these are good for sound proofing in a home theater? I plan on sealing these around my glass block windows. Will it suffice or is there a better item/idea from anyone.
Mijotter is offline   Reply With Quote
Old 11-22-2012, 09:17 AM   #2
Rewards Points: 236
those won't sound proof anything. but if you put, say, 10 layers of them, it sure will help.
Fix'n it is offline   Reply With Quote
Old 11-22-2012, 12:01 PM   #3
Rewards Points: 150
Well then I want to make sure I put whatever is best over the windows as, once the walls go up, I can't just redo it. Any suggestions? I've heard an extra layer of batt or doub le layer MDF with green glue and gasket over the window. Your thoughts.
Old 11-22-2012, 11:47 PM   #4
rylahn ernandez's Avatar
Thumbs up
Soundproofing your window will reduce noise levels by 75-95%. Utilizing foam pads are used for deadening reflections. While felt blankets are what the professionals use in studios and on stages for sound proofing. Hope this information helps you.
Rylahn
rylahn ernandez is offline   Reply With Quote
Old 11-23-2012, 08:31 AM   #5
Rewards Points: 236
when sound proofing, "mass" is KING !
decoupling is not far behind.
i would not "cover" a window. as in, leaving the window alone, and then covering it with a wall. i would take the window out and frame/fill the hole. this will also give you much better attenuation.
just a warning = those foam acoustical panels will do nearly nothing for sound attenuation. like these. though they look cool
http://www.ebay.com/sch/sis.html?_kw...anels+2+x+72ft
Old 11-23-2012, 12:07 PM   #6
Rewards Points: 150
Well we had the windows replaced with glass block when we moved in with a small open/close vent in the middle of each window. I won't take the windows out.
Old 11-23-2012, 05:17 PM   #7
Rewards Points: 150
I assume the glass block replaced windows to the exterior as opposed to a interior mostly glass partition. Is your concern sound transmission to the exterior (neighbor) or the hard surface inside the theatre that will cause sound reflection (echoe)? Also, when you closed up the original windows and installed glass block with a small vent; if the window was your emergency escape and rescue opening for a finished basement then this is the time you would want to put it back.
TheCamper is offline   Reply With Quote
Old 11-23-2012, 05:31 PM   #8
Rewards Points: 150
My main concern is putting all this money and work in to SP my basement only to find out the windows weren't done right and are the weak link. everything is down now so now is the time to do it right. Mainly I want a little sound coming from my basement as possible. And no the other side of the basement has the fire escape window.
Also, what would be a suitable gasket for whatever i place over the window? Thanks.
Old 11-24-2012, 12:51 AM   #9
Rewards Points: 150
Trying to figure out how to proof them as the cavitiy is only 3/4" deep. I was wondering if that sound putty would work spread over the whole window then maybe 1/2" moisture resistant drywall over that sealed with acoustic sealant. Over that is going to be 2" xps rigid foam board directly on the concrete wall then studded with bats in between then DD+GG.
Old 11-24-2012, 07:46 AM   #10
Rewards Points: 236
3/4" plate steel.
Old 11-24-2012, 11:18 AM   #11
Rewards Points: 150
Plate steel? as a soundproofing component? Here is a picture of the window.
Old 11-25-2012, 08:54 AM   #12
Rewards Points: 236
you need "mass". and you don't have much room if it. i was just thinking, cement board, that stuff is pretty solid and thin. e few layers of that would helpa lot. but remember = good bass has a way of moving things.
Old 11-25-2012, 11:37 AM   #13
Rewards Points: 150
That's a good idea. You can get 1/4" cement board. Any ideas on how to have it stay in the cavity and seal it?
Old 11-25-2012, 11:21 PM   #14
1/4 cement board would definitely fit.
Old 11-26-2012, 09:29 AM   #15
Rewards Points: 236
if you are putting a wall there, you will have extra room for sound proofing.
when building the wall, frame out around that window = don't cover it.
then build your "plug" to fit snugly in the opening.
Dual Pane Windows No Low E Glass and No Argon Gas Filling AZSun Windows and Doors 4 08-12-2011 09:10 PM
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 06:25 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
