Old 12-16-2012, 06:53 PM   #1
soundproofing/drywall question
Hello everyone, I have a odd question, but I am doing a basement reno and I took down the ceiling so I could install some roxul soundproof insulation between the wood joists, so the tenents upsatirs/downstairs won't hear too much noise. Now the roxul insulation is all up , haven't put up the drywall yet, so its just exposed joists and insulation, and I noticed the room is very quiet, dull and lifeless, no echo"s and speaking sounds kind of muffled......my question is, will the room get the "livelyness" and echo back one I put up the drywall?? The dullness of the room is annoying
gianni_boy is offline   Reply With Quote
Old 12-16-2012, 06:59 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
youll be fine.. the roxul stops the sound transfer.. drywall will reduce it a bit more even more so if you use 5/8 type x. there will be sound but nowhere near as bad as it was before u started the work
woodworkbykirk is offline   Reply With Quote
Old 12-16-2012, 07:14 PM   #3
Arrow
Its not the transfer of sound and vibration in between floors I am concerned about, that's why I installed it hahah....what I find annoying Is that when I stand in the room that I installed the roxul in the ceiling, its kind of like there is no more echo and if I clap or speak its kind of like sounds are muffled. What I am thinking is that because there is no more flat, ridged surface on the ceiling that the insulation is absorbing all of the sound and not allowing noises to bounce around.....so once I put up drywall will natural echo and livleiness come back?, its a faily big entertianment room.
Old 12-17-2012, 01:22 AM   #4
i'd be surprised if it will be as dull w/ the 'rock on. surely 'rock will bounce noise back far better than roxul. try installing a sheet or two w/ just a few screws in it; pls let us know what happens, too.
Old 12-17-2012, 09:07 AM   #5
AHH, SPANS!!!
whenever the house is framed before it is insulated it is full of echoes. after the insulation goes in before the drywall all echoes are gone and everything is muffled, that is normal. once drywall is in it sounds more like a normal room instead of a padded room, lol.. not that I know what one of those sound like
if you have hardwoods then those create more echoes and furniture usually helps balance out the echoes with hardwoods or cool looking sound buffer art hanging on the walls, especially in theater rooms.
I would recommend putting homasote boards up to the ceiling before the drywall because you will still get sound transference in that ceiling through the floor joists themselves and that will release through the drywall. mostly sounds will be heard from below when someone walks upstairs,especially with hardwoods. your insulation has sound proofed the voids in the joist cavities but not dealt with the sound transference of the wood members...
hand drive is offline   Reply With Quote
Old 12-17-2012, 09:22 AM   #6
yes, it will come back. almost as it was before.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 12-17-2012, 06:32 PM   #7
I am assuming you took all of the furniture out of the room to do your project? My experience has been once the furniture is reinstalled into the room this will go away. Furniture, drapes, and carpet tends to absorb the sounds.
doyleslaughter is offline   Reply With Quote
Old 12-17-2012, 08:16 PM   #8
it will come back. thats why those fancy studios have those styrofoam style walls to muffle the sound of the band or whatever
federer is offline   Reply With Quote
Old 12-17-2012, 08:30 PM   #9
you may have joists that are overspanned also so they are deflecting when someone walks across the floor causing the echo
Old 12-17-2012, 08:38 PM   #10
man i wish i was a carpenter!
Old 12-17-2012, 11:35 PM   #11
thats what i thought, thanks for the info, its a big relief........i thought the room would remain dead and muffled after the sheetrock. so basicaly how it works is, the drywall is a flat and rigid surface so it will reflect and allow sound to bounce around, and whatever sound does go threw it will get absorbed and prevent it from going up to the next floor? and vice versa.
And doyle, im gutting everything so no furnature yet.
Old 12-18-2012, 09:41 PM   #12
that depends on what sounds are being made. talking and TV, sure. but loud music or home theater, nope. but it will cut it down.
Old 12-18-2012, 11:05 PM   #13
Sound proofing a room is a art form by itself. Different types of noise are dealt with in different ways. Everything you do will help reduce noise levels some.
paintdrying is offline   Reply With Quote
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
