Soundproofing A Basement Apartment - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-17-2008, 05:13 PM   #1
Rewards Points: 1,062
Question
soundproofing a basement apartment
i plan to install sound insulation panels on the bottom of the beams in my basement ceiling (instead of sheetrock) so that i cannot hear my tenants upstairs.
these panels are about the size and thickness of sheetrock but the texture is somewhat more coarse so i was wondering if anything can be done to make it look pretty, i.e. paint it or finish it somehow ?
thx,
- a -
Old 01-17-2008, 06:30 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You are supposed to install those panels over framing, or an existing wall/ceiling, and then install sheetrock over it...
- Build Well -
Old 01-17-2008, 06:42 PM   #3
Question
hmmm ... if that is the case, what do i do with recess lights that buffer down only 1/2 in (i.e. are designed to expect only one layer and not two) ?
Old 01-17-2008, 06:51 PM   #4
Cut out a square (16" x 16" or so) in the existing ceiling and reset the light frames to accomodate the additional 1" or so of ceiling material. Use additional framing if need be, so that the lights are set at the appropriate depth.
- Build Well -
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
Wet Basement being fixed (pics) harleysilo Remodeling 2 01-23-2007 09:09 AM
