Old 11-30-2011, 08:07 PM   #1
soundproof wall
Hello there i live in an apartment that has one joining wall to another unit the wall is 9.3*8.1 or aprox 75 sq ft.I hear a loud television through the joining wall.Is there a way to soundproof this wall without tearing down any walls like for example adding quietrock directly onto the wall or would i have to put up wood furret and attach it to that? thanks
lenno5 is offline   Reply With Quote
Old 11-30-2011, 08:31 PM   #2
soundproof wall
Mass and isolation are always mentioned when people ask about sound proofing. Get mass between you and the other tv, and isolate the wall from whatever you put up for noise-blocking. Plug any cracks of any kind. Can you hang a very heavy blanket of some sort? How can you stop sound transmission through the common floor? Any way to address that?
Old 12-01-2011, 01:01 AM   #3
soundproof wall
honestly, for an appartment, you don't want to do anything that costs you too much money, and that you can't take with you.
Sound blankets are the absolute BEST.
I just finished sound proofing the CRAP out of my sons room (right behind the TV in the living room) And the sounds still comes from around the holes in his pocket door.... I will be putting up a nice THICK sound curtain behind his door. I have heard them before and they work FANTASTIC. Check them out
illnastyimpreza is offline   Reply With Quote
Tags
soundproof
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 02:35 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
