Soundproof Sump Pump - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-14-2011, 10:30 AM   #1
soundproof sump pump
How do you soundproof a sump pump?
stogie is offline   Reply With Quote
Old 05-15-2011, 10:19 PM   #2
Make a box and inside it line the walls with sound proof styrofoam. I did this with my sump pump, it is located in my playroom beside a spare bedroom so I had to keep it quiet. And it works. I made the box in finished plywood, stained and varnished, added a lamp on it and now looks like a piece of furniture.
jlazer99 is offline   Reply With Quote
Old 05-16-2011, 06:12 AM   #3
Rewards Points: 4,534
at the risk of offending lazer's home decorating talents, submersible sump pump's aren't particularly noisy,,, is yours a pedestal pump ? the bearings may be getting ready to take a dump,,, the sump should have a cover installed so just glue soundproofing mtl to the underside,,, you COULD even place a floorlamp on it when done .
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 05:35 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
how to soundproof a sump pump yourself? sylwia812 Building & Construction 6 08-06-2008 02:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
