Soundproof Booth
Yeah, you need to isolate the inner room. I don't think cork is going to do that very well. And any contact between the walls of your inner room and the elevator shaft means noise will get transfered. I would try to get air cushions or soundproofing foam for underneath the floor -- then have the walls supported on that base and not touching anything.
Where is your exit? You're also going to need to isolate the ceiling of the inner room from some sort of sound-blocking surface above it.
Jack Olsen
