Sound Proofing? (Basement Remodel) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-24-2007, 10:44 PM   #1
I can do it......I think!
Send a message via Yahoo to MovedTooMuch
Sound Proofing? (Basement remodel)
I am working on finishing a basement room. Before I put up the drop ceiling, I was thinking about putting in something to dampen the sound between the basement and the rooms above. I was thinking about shoving fiberglass insulation in between the beams. Any other ideas?
MovedTooMuch is offline   Reply With Quote
Old 03-25-2007, 05:33 AM   #2
Just putting insulation will deaden most sound. Not knowing your plans for the room that would suffice in most cases and can be a dramatic improvement over nothing at all. There are the cases such as building a recording/sound room or a Home Theater you most likely would want go much farther. Sound proofing theater or viewing room can provide a quite home for others even while a movie is being viewed at loud levels.
I have not yet tried these products
quite drywall (I have had literature on this company's products they also have flooring and more)
http://www.quietsolution.com/?google...FRZOUAodvDEvTQ
quite ceiling panels
http://www.controlnoise.com/recordin...io-panels.html
Mgmopar
MgMopar is offline   Reply With Quote
Old 03-25-2007, 10:51 AM   #3
Well I have two bedrooms above the room and I was planning on a home theater type room. I will probably put thick insulation and also sound dampening ceiling tiles. Good idea.
Old 03-25-2007, 06:00 PM   #4
The key to sound isolation is separation. There are plenty of pros out there giving away advice...
Good luck,
Steve
sfixx is offline   Reply With Quote
