Sound Proof Insulation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-02-2009, 09:55 AM   #1
Question
I am considering buying a new townhouse but am concerned about hearing the neighbors next door. I inquired as to the soundproofing between the walls and got this answer from the sellers:
As for the shared-wall construction, the drawings indicate the following construction: 5/8 fire-rated gypsum board, 3 of batt insulation, 5/8 fire-rate gypsum board, 1 of air space (the divide between the two houses), 5/8 fire-rated gypsum board, 3 of batt insulation, 5/8 fire-rate gypsum board. The batting is fiberglass.
I don't know what this means in terms of noise insulation and was hoping someone could shed some light on this issue. I currently live in an older townhouse with a cinderblock divide with plaster on top. Unusually loud noises transfer but for the most part it is pretty quiet and I'm hoping to have equal if not better sound proof living if I move. Also, if this isn't great soundproofing, is there anything I can do to improve it?
Any help is much appreciated!!
jenrosewv is offline   Reply With Quote
Old 07-02-2009, 10:12 AM   #2
You only need 1 thread asking for assistance
Other thread:
Old 07-02-2009, 11:00 AM   #3
Sorry. I'm new. I tried to remove the other post with no luck. Just wasn't sure where to post.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
sound insulation Master Brian Remodeling 4 05-19-2009 01:03 PM
Sound insulation for home theater room david.plymouth Building & Construction 3 02-08-2009 09:49 PM
Insulation question Outbacker HVAC 16 12-29-2008 09:54 PM
