Sound Insulation: Changing Interior Hollow Core Door To Solid Core, Or Exterior Door? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 12:30 AM   #1
Rewards Points: 37
Sound insulation: Changing interior hollow core door to solid core, or exterior door?
Hello all, I thought I'd post this in this section for more advice.
A follow up from this post:
Adding door in hallway between two rooms
We ended up adding a prehung 30" hollow-core interior door between the two bedrooms. However, the door provides NO soundproof at all, it's very easy for the kids to stay awake when a conversation is being held in the adjacent room.
We want it to be sound proof, so the thought of getting a fiberglass exterior door came to mind. Is that overkill? Are they any more soundproof than a solid core interior door? Also, there won't be much traffic going between the two rooms, so the extra weight of the exterior door would be ok.. we just want it to be very sound proof. I'm also thinking of adding some insulation behind the drywall above the door..
How does MDF compare to solid wood?
http://www.homedepot.com/Doors-Windo...atalogId=10053
Lastly, if we're going from hollow core so solid-core or even from hollow core to exterior door, would we need to change the door frame or hinges?
aminus21 is offline   Reply With Quote
Old 03-10-2011, 01:43 AM   #2
Rewards Points: 1,092
When sound-proofing cats chime in on these questions, they always say "Mass, mass, mass." So, yes, a more dense door will stop more noise. What, though, about the top, bottom and edges of the door? What are you going to do to stop noise blasting right through the cracks? That needs addressing. Tacky and gross, but can you hang a sheet of sheet rock on the door you have, and paint it? EPDM gaskets may work for the top and bottom cracks. And, while you are at it, what about the walls around the door? Insulated? Double sheet rocked? Etc. Good luck. j
Need soundproof: Changing interior hollow core door to solid core, or exterior door? aminus21 Remodeling 4 03-08-2011 03:19 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
