Sound Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-23-2008, 05:13 PM   #1
Rewards Points: 264
sound insulation
Is Sound Control insulation the same as standard batts, just without the paper? I did not think so, but a sales guy told me that recently. I am doing a small remodel and want to look at options to insulate the mech closet for sound.
7echo is offline   Reply With Quote
Old 09-23-2008, 06:25 PM   #2
concretemasonry's Avatar
Rewards Points: 2,566
Fiberglass in realy not very good for sound.
If you can get rock wool or similar batts (various brand names), this is much better.
Dick
concretemasonry is offline   Reply With Quote
Old 09-24-2008, 05:23 AM   #3
Rewards Points: 156
pressed fiberglass panels
Fiberglass will absorb sound but you have to buy it in the form of pressed panels. Most sound baffles you see in large auditoriums are made of this. It comes in sheets from 1" to 2" thick. You have to cover it with some sort of cloth though. It's expensive too.
jayp is offline   Reply With Quote
Old 09-24-2008, 08:22 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Fibreglass thermal insulation is NOT the same as sound attenuation insulation. Sound dampening insulation does a better job, but is far from soundproof.
Old 09-24-2008, 09:36 AM   #5
Registered User
Termite's Avatar
My experience has been that adding sound attenuation batts in a residential situation is basically ineffective unless measures are taken in the application of wallboard to reduce sound as well (resilient channel, offset studs, etc).
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Soundproof Windows BlueJello General DIY Discussions 3 11-30-2007 06:34 PM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
