Sound Deadening - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-04-2009, 08:07 PM   #1
Rewards Points: 150
sound deadening
I'm planning to finish a room in my basement that will have a TV with a moderate surround sound deal. Above is my living room with a hardwood floor. So I was wondering are there any tricks short of the complex sound proofing systems to help reduce the transfer of sound upstairs? Will simple fiberglass insulation help? I'm planning on recessed lighting so it seems some of the double thickness solutions would be problematic.
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 01-04-2009, 08:20 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
I believe mineral wool or mineral fiber has superior sound insulating properties over fiberglass. I also believe it is quite a bit more expensive.
Angus
My Albums
angus242 is offline   Reply With Quote
Old 01-05-2009, 08:52 AM   #3
Registered User
Termite's Avatar
They do make sound attenuation batt insulation that will help. It is usually mineral fiber based, and not fun to work with. Whether you use them or not, insulating will help, but you need to use mineral fiber and not conventional fiberglass.
However, the #1 thing I would do is install resilient channel or "hat" channel before installing the sheetrock ceiling. Resilient channel is light gauge metal and runs perpindicular to the floor joists, screwed to each joist where it intersects. The rock is screwed to the channel and not to the joists. This greatly reduces the points of contact between the rock and the joists, which results in reduced sound (vibration) transmission. It is cheap and easy to do.
In this picture they put it on the walls too, which you don't need to do.
constant running water sound gmk2008 Plumbing 9 11-11-2008 08:22 PM
Soundproof Windows BlueJello General DIY Discussions 3 11-30-2007 05:34 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 10:22 AM
Leaky Water Sound 24/7, need your advice. clue89 Plumbing 1 03-02-2007 07:36 AM
