Sound Barrier Between Basement And Main Living Area. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-18-2011, 06:20 PM   #1
Sound barrier between basement and main living area.
Hardwood flooring throughout home (1650 sf). Basement is concrete floor. We want to finish the basement (rec/family area) in the future, but in the meantime, noise from up and down is an issue. I want to fill rafters with insulation, but my husband says this won't help. I think it will. Anyone have a solution? I can't even call a friend after 10 PM w/o waking him up, so I seriously need some help with this... Any one ?
truartcle is offline   Reply With Quote
Old 08-18-2011, 09:48 PM   #2
Rewards Points: 1,092
that is the best use of fiberglass batts, though installing overhead REQUIRES, imo, a tyvek siut, eye and face protection. cotton, wool, etc, batts are less worrisome. if temporary, skip the double sheet rock, etc routine.
Old 08-19-2011, 10:44 AM   #3
Rewards Points: 85
What to use to cover the fiberglass batts?
quincy is online now   Reply With Quote
Old 08-19-2011, 12:30 PM   #4
AGWhitehouse's Avatar
Fiberglass batts will help with higher frequency noises like voices, but won't help with lower frequencies like footsteps. If you are trying to block you voice & tv from the basement level up to the first floor, then fiberglass batt and acoustical ceiling tile & grid would be a good/cheap start.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
Renovating basement, main too full: sub panel plan, OK? renoman Electrical 6 08-18-2010 10:32 PM
Moving ductwork to accomodate finished basement Badfish740 HVAC 1 01-13-2010 03:11 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
Basement toilet: Watergenie - how to connect to main stack GD73 Plumbing 1 12-21-2009 10:13 AM
