#1 |
sonotubes under a concrete slab
anybody ever heard of pouring a concrete slab over a sonotube enclosed area. Such as a 24 x24 garage. Place sonotubes around the perimeter and then pouring the concrete slab. The sonotubes would maybe act as a frost wall. Ok heres your chance to tell me im an idiot
#2 |
You would need a thicker structural slab that is reinforced with rebar. The thickness and spacing of rebar will depend on the slab size and the Sonotube spacing.
What part of the world are you hiding in (no location provided in the profile). The climate has something to do with the answer. Dick |
#3 |
MarginallyQualified
sonotubes under a concrete slab |
#4 |
I have seen sidewalks over unstable soil done similar to the sink a few sonos in critical areas to act as foundation and pour the slab.
Do not PM with questions that can be asked in a forum. I will not respond. |
#5 |
Concrete & Masonry
I've only done this once, and it was a building that housed bovine. I wouldn't suggest it, especially if you have a building dept. to answer to.
#6 |
DO it all the time for attached garages. Thicken the edge of the slab.
#7 |
Im in the north east. I dream this stuff up and wonder why not. No I didnt get a hundred sonotubes. I guess I should of given more information. I was thinking of building a pole barn type of building. And using sonotube to construct the pole barn on. With this building there is no center wall, all open. I was wondering how I would pour a cement slab in the middle of this thing.
#8 |
And what's going to keep the walls from swaying if the post are not sat into the ground?
The inside area is going to have to be back filled enough so the siding is at least 6" above the grade. SO the siding does not come near the grade. Anytime I've seen or built a pole barn we use 6 X 6's set in the ground at least 2' (below the frost line) holes get back filled with concrete, A trench gets dug out around the outside even with the post to form a berm so the slab will be thicker on the outside edges, form boards get screwed to the outside of the post so the center of the slab will be at least 4" thick. You should lay 6 mil. plastic down before the pore as a vaper barrier. If it's to be heated you could also lay foam down. Personaly I think this is a job for a pro concrete finisher not a DIY. It's a one shot deal, done wrong and there's going to be low spots, cracks ect. Once that truck shows up there is no going back. |
#9 | |
sonotubes under a concrete slabQuote:
Pole barns sink the poles in the ground and have no concrete piles or concrete floors usually (around here anyway). As soon as you are doing all that concrete work anyway you may as well build a frame building, it will actually be easier and cheaper. |
#10 |
I'm not building a pole barn, only a covered patio. do sono-tubes require footing? (42" below fg)
#11 |
In some areas yes they do.
#12 |
Wire Chewer
My fear would be that the slab's movement would counter the sonotube movement, and you'd get cracking. For example if the sonotube concrete pillars are pushed because of the frost, you'd get a bunch of bumps in the slab with cracks. Best to keep it uniform. Now if the pillars are strictly holding the entire slab up with zero dependance on the ground, then you'd be ok, but that would be more involved to build. Then again, I'm no expert here, maybe I'm way off.
#13 |
Why not dig a perimeter trench about 8" wide down below the frost line and pour a monolithic slab with the plates right on the perimeter of the slab.
If you have the right height if not go to plan B. |
| Tags |
concrete floor, slab, sonotube ![]() |
| Display Modes | |
| concrete porch slab questions | Queso Bandit | Building & Construction | 2 | 06-29-2011 11:31 AM |
| Fix or Replace Porch Concrete Slab | Majoram | Building & Construction | 10 | 06-25-2011 03:45 PM |
| Help stone over concrete slab | Johnnyquest | Flooring | 0 | 05-20-2011 04:36 PM |
| Concrete slab to foundation work | tntgarv | Building & Construction | 3 | 02-28-2010 01:23 PM |
| PVC underneath the floor (concrete slab) | massimo | Building & Construction | 6 | 11-19-2008 11:37 AM |
