Old 07-01-2009, 11:05 AM   #1
Default sonotubes for retaining wall?
I need to build a retaining wall under an existing deck, where there's not much space to maneuver. The wall will be about 4' high (maybe a bit higher on one end, and a bit lower on the other) and about 12 to 15 feet long. Around here, a lot of people build retaining walls by digging deep holes (like about 2x as deep as the wall height) and putting in metal beams. Then they fill the holes with concrete to hold the beams in place, and pressure treated lumber (2" thick, or 4" thick) is used for the wall itself. The beams are generally placed about 6' OC.
In my case, the limited space would make it virtually impossible to get long steel beams in place, so I was thinking that concrete poured into sonotubes could work in place of the steel beams. Any thoughts on this? Any specifics, like how deep to go, beam spacing, suggested diameter of sonotubes, etc.? Thanks.
Jeremy Hillary Boob, PhD is offline   Reply With Quote
Old 07-02-2009, 12:29 AM   #2
You would want what they have. Ask your building department as to frost depth for your local area.
To prevent frost heave: http://books.google.com/books?id=1gg...num=3#PPA31,M1
Be safe, G
GBR in WA is offline   Reply With Quote
Old 07-02-2009, 10:35 AM   #3
Be safe, G
I was hoping that someone on this forum might have seen something similar to what I'm considering and have some useful thoughts on the matter, but, apparently, that's not the case. Anyways, there are no frost issues here, just earthquakes.
Yesterday I did notice someone in the neighborhood has a retaining wall that is exactly the sort of thing I'm considering doing. So, I guess I can have "what they have" and what I want too. Hopefully, the current owner put in the wall and can provide me with some of the details.
Old 07-02-2009, 07:20 PM   #4
You'ld probably have to go quite deep for the sonotubes and put a lot of rebar in them. The soil has a tremendous amount of pressure and can easily tip over retaining walls that aren't designed right. The soil pressures will depend greatly on the type of soil you have. Almost everyplace requires engineering for retaining walls 4' high.
But, have you considered a modular block retaining wall? They would be easy to move under your deck. They don't require a concrete base and can be layed with minimal excavating (usually placed on some compacted gravel). I'm pretty sure the manufacturers have engineering data to support using their product at appropriate heights.
Another thing to consider is breaking that 4' rise into two 2' rises spaced 3 or 4 feet apart. I would think modular blocks would easily handle 2' of nearly any soil conditions.
Old 07-02-2009, 08:23 PM   #5
Tool Geek
PaliBob's Avatar
Originally Posted by Jeremy Hillary Boob, PhD View Post
.... Anyways, there are no frost issues here, just earthquakes.....
If you are hinting at California, then here there is also just sliding.
There are super strict rules in California on retaining systems. If you are close to LA PM me and I can give you some first hand info.
Here is a pdf on general requirements:
http://www.documents.dgs.ca.gov/dsa/...v_09-18-07.pdf
The idea of using concrete blocks is good, but at least in CA, a foundation is required. The height to grade is also measured from the bottom of the foundation.
Here is a PDF on a CA city requirements for Retaining Walls, which is very similar to those in LA.
http://www.atascadero.org/files/CD/R...ndout.2.11.pdf
I would advise that you visit your local Building Department and get their handouts on the Rules and Regulations.
Disclaimer
& Stay Safe
.....Bob
Old 07-02-2009, 08:57 PM   #6
I'm in northern California.
Unfortunately, the local building department makes it virtually impossible to do anything, so, predictably, almost everything is done without permits. My plan is to overbuild by a large degree.
Thanks for the suggestions of a segmental retaining wall, and I have thought about that. However, I still like the sonotube idea, since I can use them as piers to support the deck, and also as a retaining wall---making the retaining wall just high enough to keep dirt away from my exterior walls (less than 4' might actually do it).
Anyways, I have found a neighbor who did something like this (actually, much more aggressive than what I've got in mind), so I'm going to check and see how he managed it.
Old 07-02-2009, 09:53 PM   #7
Tool Geek
PaliBob's Avatar
[size=2]
....where there's not much space to maneuver. The wall will be about 4' high ...and about 12 to 15 feet long. ... so I was thinking that concrete poured into sonotubes could work in place of the steel beams.
There is a huge range of sonotube Sizes:
http://www.sonotube.com/products/son...sizechart.html
But installing them under an existing deck presents some problems
  1. How are the deck joists supported now?
  2. How much space is there now between ground and the bottom of the joists
  3. Are the deck boards nailed or screwed?
There are too many unknowns, Can you post some pics?
Disclaimer
& Stay Safe
.....Bob
More On This Topic
If moving walls is in your plan, there are several things to consider. You want to consider what is in the wall. Is there electric in the wall? Is there plumbing in the wall? Where is it? Where can you move it? Can you take it out? What would be the... Read More »
We are going to talk a little bit about the demolition that we had to do to get started with this project. As you can see this wall along here has been exposed. You can see the 2x6 construction. We came in and decided where the new door should be into... Read More »
Insulation lowers energy costs and cuts down on noise. Most homes have garages with insulation between only the garage and an exterior house wall. Today, more homeowners are choosing to insulate their garages and turn the extra space into a shop or... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When you're framing your basement by yourself, or if you've hired someone else to do it, one thing to think about is the spacing that you will use to space... Read More »
Depending on your location and the condition of your soil, it is sometimes the best option to concrete in your mailbox. You mailbox serves several functions. Not only is it a receptacle for your mail, which must be dependable, but it is also a marker for... Read More »
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 05:29 PM
Wall cap for masonry wall cliffslocal Building & Construction 1 04-01-2009 03:59 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 07:39 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 05:44 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 11:47 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
