Sonotube Spacing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-03-2007, 03:33 PM   #1
Rewards Points: 150
Sonotube spacing
I'm planning on building a shed in my back yard, approximately 16' x 20'. What is the recommended spacing between sonotube footers to build the shed on?
billinak is offline   Reply With Quote
Old 05-03-2007, 04:24 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
You can put the sonotubes wherever you want.
What is important is what the shed structure has for bearing points or supports.
Are you building a very small "pole building" type structure or a framed shed off a platform or beams? If the second, what can your support beams span?
concretemasonry is offline   Reply With Quote
Old 05-03-2007, 05:31 PM   #3
Rewards Points: 150
I was planning on a framed shed on a platform. Based on some of the other research I've done, it looks like 8 feet will probably suffice. I'm planning on submitting the drawings and getting a permit, so when the muni reviews the drawings, they should weigh in on the spacing.
shingle seam spacing fredhedd Roofing/Siding 7 04-08-2009 07:52 AM
rafter spacing Clutchcargo Building & Construction 5 08-11-2007 03:14 PM
spindle spacing jibber Carpentry 5 02-18-2007 09:30 PM
Sonotube patio supports sharisavage Building & Construction 2 05-14-2006 11:01 AM
Spacing flooring Servant_ Flooring 1 12-03-2005 07:31 PM
