-   -   Sonotube spacing (http://www.diychatroom.com/f19/sonotube-spacing-8205/)
billinak 05-03-2007 02:33 PM
Sonotube spacing
I'm planning on building a shed in my back yard, approximately 16' x 20'. What is the recommended spacing between sonotube footers to build the shed on?
concretemasonry 05-03-2007 03:24 PM
You can put the sonotubes wherever you want.
What is important is what the shed structure has for bearing points or supports.
Are you building a very small "pole building" type structure or a framed shed off a platform or beams? If the second, what can your support beams span?
billinak 05-03-2007 04:31 PM
I was planning on a framed shed on a platform. Based on some of the other research I've done, it looks like 8 feet will probably suffice. I'm planning on submitting the drawings and getting a permit, so when the muni reviews the drawings, they should weigh in on the spacing.
