Sonotube Size? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-23-2010, 08:58 AM   #1
Sonotube size?
What size of sonotube do I need?
I will be installing a 12 x 14 enclosure around my hot tub. The hot tub only will be sitting on a base of crush stones 0 / .75 and about 20 deep. I need to know what size of sonotube to use for my concrete posts (9 of them). The posts will be completely filled with concrete whit an adjustable patio support screwed on top of them. The frost line is 48. The floor will be made of 2 x 6 pressure treated wood and spaced 12 apart. The contour, however, will consist of 2 pieces of 2 x 6 and .5 plywood between them; all glued and nailed together to fit properly in the supports. Thanks. MarcHRob
MarcHRob is offline   Reply With Quote
Old 05-23-2010, 07:20 PM   #2
Rewards Points: 1,668
Why not ask the building inspector? He will likely come by before the pour to make sure all is correct; might as well find out ahead of time.
bob22 is offline   Reply With Quote
Old 05-23-2010, 10:15 PM   #3
Rewards Points: 1,910
Useful link
http://lincoln.ne.gov/city/build/home/deckload.htm
Check with your building dept to see if they have something similar.
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
pre-hung door, 32x80 is that door size or total size? RyanD Building & Construction 3 06-28-2009 10:33 PM
Room size X floor tile size deck hand Flooring 4 04-08-2009 04:42 PM
duct work size justmefixin HVAC 2 09-20-2008 06:59 PM
