Sonotube Patio Supports - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-13-2006, 02:05 AM   #1
Construction Junkie
Sonotube patio supports
Anyone have any experience with using Sonotube to pour colums for a pergola? I could also really use some websites with designs if anyone has any suggestions. thanks.
sharisavage is offline   Reply With Quote
Old 05-13-2006, 12:05 PM   #2
Darylh's Avatar
Using sono tube for this is a great idea but do you home work for sure.
I googled concrete columns and came up with a ton of info but here is one link.
http://www.spec-net.com.au/company/ezytube.htm
Hope thi helps
Darylh is offline   Reply With Quote
Old 05-14-2006, 11:01 AM   #3
Contractor
Check with your bld. dept. for size and depth. Around here, we need inspections.
Teetorbilt is offline   Reply With Quote
slumped patio fix ?? houser Building & Construction 5 03-18-2010 07:25 AM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 11:03 PM
Need help with patio cover supports alexfosse Building & Construction 2 05-02-2007 04:57 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
Moving Header Supports Star Building & Construction 3 09-25-2005 01:50 AM
