Old 10-15-2006, 07:38 PM   #1
Some Basement Insulation Questions
I am finishing my basement and I am insulating the ceiling and interior walls with Roxul Safe N Sound. When I insulated the ceiling I pushed the insulation up against the underside of the floor. Will the insulation eventually sag and fall onto the drywall? Should I use something to support it and if so, what? My house is a semi-detached and I want to insulate the common concrete wall that separates the two basements. Is this ok? A friend told me a contractor told him not to insulate this wall because of moisture concerns. If I insulate the common wall should I use vapor barrier as well?
Thanks in advance for any suggestions
atilla137 is offline   Reply With Quote
Old 10-15-2006, 10:12 PM   #2
concretemasonry's Avatar
Location: Minnesota - Longitude 45.057 Latitude -93.074
Why do you want to insulate the common wall? Is the other side too hot or cold?
Insulation would do nothing to help with sound.
concretemasonry is offline   Reply With Quote
Old 10-16-2006, 10:00 AM   #3
Lightbulb
FOr foam panel or any type of battr/roll insulation, you can use Simpson Strong-Tie insulation supports. These are thin spring steel rods with sharp ends that you arch into place under the insulation; the sharp ends are poked into the the sides of the joists holding the insulation in place. They come in different lengths, just match the length to your joist spacing.
Colonel Hogan is offline   Reply With Quote
Old 10-16-2006, 11:06 AM   #4
Insulation specifically designed to block sound will do nothing to help with sound??? That doesn't make ANY sense!.
Old 10-16-2006, 11:07 AM   #5
Exactly what I needed. Thank You
Old 10-16-2006, 12:26 PM   #6
atilla 137 -
What I meant about sound was that if you have a concrete common or party wall, adding lightweight insulation will do next to nothing to decrease the sound transmission through the wall. The sound transmission depends on the wall weight.
Even resiliant channels or sheet lead would have a very minor reduction in sound since you alread have a 55+ db rated wall. You might add 1 db to the rating at best, since it is very difficult and costly to improve on a solid wall.
If you are building a wood frame wall in front of the concrete, you can add insulation between the studs with no problem, but it would really be a waste of money. Your concrete wall would have a 55+db rating and a wood wall with insulation might be 40db, but the resulting total would be about 56db since you cannot add db's to get a total db rating. The db ratings are a logarithmic value they cannot be added.
Once you are in the area of 55 db, it is very difficult to increase the db rating. As an example, going from one 8" wall to 2 - 8" walls (one one 16" wall), the db rating would only go up to about 57 or 58 db.
If you have a unique problem. you might want to take a look at the area above the concrete wall. This is an area susceptable to sound transmission and the transmission of vibrations from the adjacent portion of the wood structure.
If you are talking about a wood stud or a steel stud (worse yet), then resiliant clips or channels for the sheet rock are the way to go.
I would not add a vapor barrier to the wall since both sides of the common wall are conditioned or semi-conditioned spaces and will have the same conditions on both sides. Tradition says put the vapor barrier on the warm side - what if your neigbor has his heat higher than yours? You certainly do not want a wall with a vapor barrier on both sides.
Old 10-16-2006, 12:57 PM   #7
Thank You
I think that you are right about the sound coming through the wood above the common wall. I have insulated the ceiling and the wood above the concrete wall. You obviously know your 'crete!
Thanks Again
Atilla137
More On This Topic
Hi, this is Jon on behalf of Expert Village. In this video clip we will be detecting wood studs. When detecting wood studs, the first thing we need to do is set our stud finder to wood to tell it that we are in fact going to be detecting wood studs... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. The insulation is a project that's very simple and and something I would actually suggest for a homeowner to try to do themselves. In this home here we... Read More »
If you have the need to store large amounts of ice, building an ice house is a project for you. Popular many years ago, now most freezers now come equipped with ice makers to produce a sufficient amount of ice for a family, but are not designed to handle... Read More »
Insulation lowers energy costs and cuts down on noise. Most homes have garages with insulation between only the garage and an exterior house wall. Today, more homeowners are choosing to insulate their garages and turn the extra space into a shop or... Read More »
Hi, we are going to be insulating these walls. It’s an older house and we recently discovered despite our thoughts they are indeed not insulated in the walls. These walls are a little harder to tell exactly where the studs are. You can kind of... Read More »
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Building & Construction 14 01-18-2010 08:52 PM
Basement "Edge" insulation Wil Building & Construction 3 04-05-2007 11:04 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
