Some Basement Framing Question - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-28-2011, 05:25 PM   #16
Registered User
Rewards Points: 5,516
Give you some background: http://www.buildingscience.com/docum...lation-systems
http://www.quadlock.com/technical_li...Insulation.pdf
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
MecGen (01-01-2012)
Old 12-29-2011, 09:17 AM   #17
Rewards Points: 131
Originally Posted by GBR in WA View Post
ok thanks when using foam between joist to my wall top plate, is it always necessary to install sill gasket
is this my modify picture look correct for basement wall - concrete insulation.
is the sill gasket necessary or i can spray foam directly to wood & concrete.
there is gap between concrete fundation vs the wall stud(even after install fiberglass between each stud). does this gap need to be fill with foam or other installtion to keep condensation to a minimal.
s002wjh is offline   Reply With Quote
Old 12-30-2011, 11:26 PM   #18
Registered User
A picture would help me understand your wall make-up as it is now. The sill gasket is a capillary/air/thermal break under the p.t. sill plate: http://www.greenbuildingadvisor.com/...-building-code The upper wall sits on a sill sealer to stop air movement to the exterior, caulking will work. It is pictured at the plate/plywood sub-floor junction.
Fiberglass won't work as an air seal at the rim joists.
Gary
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Basement Remodel - HVAC Code Question buckybadger HVAC 2 08-16-2011 05:34 PM
Question regarding framing a basement wall James0816 Building & Construction 0 05-28-2010 09:41 AM
Framing Basement question markethound80 Remodeling 3 05-21-2010 12:10 PM
Basement framing insulation question Bcoleman6 Building & Construction 5 03-21-2008 06:37 PM
