Some Basement Framing Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-25-2011, 04:05 PM   #1
Rewards Points: 131
some basement framing question
so i'm try to do some framing work in my basement. one issue I encounter is one of the wall is parallel to the floor joist, which mean i can't connect the top plate to the joist without bump the wall forward another 10". the wall is 14 feet, is it okay to use an L bracket to make a connection between top plate and joist every other stud??
same thing with another wall 18' which has water/gas pipe hanging from joist. can i do the same with L bracket.
parallel wall with joist
wall with pipe hanging
s002wjh is offline   Reply With Quote
Old 12-25-2011, 04:41 PM   #2
DIY staff
Rewards Points: 7,174
I usually attach the walls to wood blocks that are gunned to the foundation itself.
Or add wood blocking between the rim joist and the first floor joist and nail upwards into those.
---If you could resize the pictures more people will respond.--Mike---
Old 12-25-2011, 05:37 PM   #3
Rewards Points: 131
so the 1st method require drill hole into concrete wall?
pic resized
Old 12-25-2011, 05:46 PM   #4
DIY staff
I gun them in with a .22 caliber stud gun--cheap tool and fast.
I take a couple of 2x4 shorts (about 16" or so) and nail them together,side by side, so they are L shaped when looked at from the end.
First ,gun the wall to the floor--then get the wall plumb--left to right--position the blocking against the foundation---gun it to the foundation with 2 or 3 shots--
Next--pull the wall forward until it's plumb--and nail wall to the block.
Old 12-25-2011, 05:53 PM   #5
Rewards Points: 131
i see thanks.
so if i attach L block from wall top plate to the next joist is not a good idea?
Old 12-25-2011, 06:02 PM   #6
DIY staff
I don't know what you mean by an L block--Sorry--
Old 12-25-2011, 06:21 PM   #7
Rewards Points: 131
something like this an horizontal 2x4 parallel to joist attach to wall's top plate, the end of horizontal plate is attach to a vertical 2x4, which is attach to the 7 inch joist side by side.
can i do this?
Old 12-25-2011, 07:12 PM   #8
DIY staff
That looks like it would be weak and wobbly--can you get blocking all the way from the joist to the outside rim joist--above the pipes--then add some blocking down to the wall top?
Old 12-25-2011, 07:36 PM   #9
Registered User
Rewards Points: 526
You have good eyes, Mike! Lol, I can hardly see that......
s002, be sure to foam board the rim joist and air seal it with canned foam before you add the 3/4" plywood (or other) behind the new wall out from the concrete wall for required fire-stop. At vertical wall to horizontal joist cavity as per minimum Code; http://publicecodes.citation.com/ico...002_par031.htm
Gary
Old 12-25-2011, 10:07 PM   #10
Rewards Points: 131
the problem is the joist is perpendicular to the pipe. if the pipe is not there i can connect the stud directly to the joist.
the red horizontal line is the joist, perpendicular to the pipe. the vertical red line is the height of joist. the new wall is beneath the middle two water pipe(gap between pipe is about 2-3inch, not enough space for 2x4)
Old 12-25-2011, 10:12 PM   #11
Rewards Points: 131
Gary
ok thanks gary. i didn't even think about firestop. basically for fireblock as long as there are insulation or foam to fill the empty space between stud or space between wall and concrete, between ceiling and 1st floor, then it should be fine? basically fill any gap with something to minimize spread of fire from vertical to horizontal or between studs?
there are insulation attach to the concrete foundation(see above pics, silver foil cover for the insulation), do i need to take those off, add plywood between my wall and concrete for proper fireblock ? or i can keep those on, just add plywood or 2x4 blocks against the insulation?
also any other things i should do? i never frame wall before so please let me know if anything worth mention thanks
Old 12-25-2011, 10:28 PM   #12
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
why dont you strap the ceiling first with 1x4's. by doing this you'll have something to attach the top of the wall to something solid.
woodworkbykirk is offline   Reply With Quote
Old 12-25-2011, 10:35 PM   #13
Rewards Points: 131
well, i need to build a soffit beneath the pipe, there is a vent on right side of gas pipe(black). so i was think attach the one end of soffit to the wall top plate, would that work? the other end of soffit will attch to joist.
Old 12-27-2011, 10:17 PM   #14
Registered User
Rewards Points: 526
On fire-blocking and draft-stopping; How to fireblock framing first two pages cover drop soffits and wall/ceiling.
The foil-faced is not air-tight to stop air movement and moisture; http://www.buildingscience.com/docum...-at-rim-joist/
Gary
Old 12-28-2011, 09:00 AM   #15
Rewards Points: 131
Gary
so I have to remove the insulation/foil that is anchored to the concrete fundation, then install wall/fireblock etc? there is no other way to keep the insulation on the concrete wall?
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Basement Remodel - HVAC Code Question buckybadger HVAC 2 08-16-2011 05:34 PM
Question regarding framing a basement wall James0816 Building & Construction 0 05-28-2010 09:41 AM
Framing Basement question markethound80 Remodeling 3 05-21-2010 12:10 PM
Basement framing insulation question Bcoleman6 Building & Construction 5 03-21-2008 06:37 PM
