Solution For Silicon? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-03-2010, 12:26 AM   #1
Solution for silicon?
I'm trying to get some old (but not very old) silicon caulk from a lightly porous surface. Some friends recommended hydrochloric acid. The silicon repels it handily. Does anyone out there know what will disolve this stuff?
Thanks in advance!
Bodgey Builder is offline   Reply With Quote
Old 09-03-2010, 05:43 PM   #2
Rewards Points: 5,336
You will not dissolve the caulking. You can remove most of it by cutting, and you might remove the residue by sanding.
Ron
Old 09-03-2010, 05:49 PM   #3
fabrk8r
fabrk8r's Avatar
The only way I know to remove silicone caulk is by abrasion.
Sometimes it can be scraped off with a sharp razor blade, but there is usually some residue left that will need to be removed by abrasion of some sort,
especially if you are working with a porous surface.
I wouldn't recommend using hydrochloric acid for a couple reasons. The fumes are noxious and hazardous. Also it is so caustic it may damage the surface you are trying to restore.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-03-2010, 06:02 PM   #4
kwikfishron's Avatar
Rewards Points: 818
Pumas stone and soapy water works good on the residue.
kwikfishron is online now   Reply With Quote
Solution for Bad Advice - Latex on Bookcase greenthumb General DIY Discussions 8 08-16-2010 05:58 PM
two fan solution from a tucked away kitchen amakarevic HVAC 0 02-25-2010 11:18 AM
Need HVAC solution for basement - 3 zone? or ductless units? skylake HVAC 2 10-06-2009 07:42 PM
Need lighting control solution mmccarty Electrical 9 08-25-2009 09:13 PM
unconventional solution nique Plumbing 5 12-10-2006 10:34 AM
