-   -   Solution for silicon? (http://www.diychatroom.com/f19/solution-silicon-80409/)
Bodgey Builder 09-03-2010 12:26 AM
I'm trying to get some old (but not very old) silicon caulk from a lightly porous surface. Some friends recommended hydrochloric acid. The silicon repels it handily. Does anyone out there know what will disolve this stuff?
Thanks in advance!
Ron6519 09-03-2010 05:43 PM
You will not dissolve the caulking. You can remove most of it by cutting, and you might remove the residue by sanding.
Ron
fabrk8r 09-03-2010 05:49 PM
The only way I know to remove silicone caulk is by abrasion.
Sometimes it can be scraped off with a sharp razor blade, but there is usually some residue left that will need to be removed by abrasion of some sort,
especially if you are working with a porous surface.
I wouldn't recommend using hydrochloric acid for a couple reasons. The fumes are noxious and hazardous. Also it is so caustic it may damage the surface you are trying to restore.
kwikfishron 09-03-2010 06:02 PM
199 Attachment(s)
Pumas stone and soapy water works good on the residue.
