Solid Surface Counters On Floating Vanity - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-12-2011, 04:06 PM   #1
Solid surface counters on floating vanity
I would like to install a floating vanity for my bathroom. The counters will be solid surface, quarts or granite. Will a floating vanity (assuming installed correctly) provide enough support for the weight of the counters? What kind of extra structural support might I need?
acerunner is offline   Reply With Quote
Old 07-12-2011, 06:38 PM   #2
Rewards Points: 5,336
The support would depend on the weight involved. The weight involved would depend on the size of the vanity and how it was constructed.
Do you have any plans for this unit?
Ron
B. Franklin 1759
Old 07-12-2011, 06:53 PM   #3
sorry, forgot dimensions.
Its going to be 48"W x 18"D x ~16"H . It will be installed in a corner, so support on two sides is possible. The counter is about 3/4" thick.
Old 07-12-2011, 10:28 PM   #4
Does it matter if the supports are visable? If not, you can weld up "L" brackets and bolt them to the framing and sit the vanity on top.
If you don't want to see them, you'll integrate the brackets into the vanity structure.
Ron
B. Franklin 1759
Old 07-13-2011, 10:00 AM   #5
AGWhitehouse's Avatar
Ron nailed it...I'd recommend the metal support too. The counter weight isn't what to worry about. It's someone leaning (or sitting) on it to wash the mirror or any other random act of putting their weight on it.
AGWhitehouse is offline   Reply With Quote
Old 07-13-2011, 07:18 PM   #6
yes, i would like to keep it hidden. I was thinking of using large L brackets, or integrated shelf brackets. Shelf brackets (triangle vs simple L) would be much stronger, but are harder to hide. I have yet to find available brackets in the correct size, 18". I would like to be able to support the entire depth. Largest bracket I've found is 12". Welding my own is an option, but my access to a welder is limited.
My second choice would be a french cleat. How well would a french cleat work in this situation?
Old 07-13-2011, 09:44 PM   #7
I would have the brackets fabricated by a welder myself unless your certified.
If using a french cleat it would need to be the Charles De Gaulle of french cleats.
Ron
B. Franklin 1759
build a floating vanity klmeenan Carpentry 9 06-21-2011 11:19 PM
bathroom remodel at a stand still becuase of floating vanity installation diy'er on LI Kitchen & Bath Remodeling 10 11-23-2009 02:12 PM
solid surface 7echo Remodeling 4 02-02-2009 05:22 PM
solid surface estimate 7echo Remodeling 9 09-01-2008 10:24 AM
Trying to decide between granite or solid surface countertops Proulx06 Remodeling 13 02-01-2007 09:23 AM
