Soil Load Capacity Test And Ground Wire In Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-18-2012, 06:45 AM   #1
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 740
Soil Load Capacity Test and Ground Wire in Floor
I'm having a soil load capacity test done soon and I need to make two 24''x24'' holes and take them down to the bottom of the footing. They must be on opposing corners of the house. I have one done and ready to do the second.
In the room for the second hole, I have a ground wire going into the cement of the basement floor and was curious how it terminates under there before I start cutting.
Soil Load Capacity Test and Ground Wire in Floor-cid_51068852-d73b-47b4-bbc5-521fe0cf171b.jpg
123pugsy is online now   Reply With Quote
Old 10-18-2012, 10:05 AM   #2
Rewards Points: 13,300
It sould connect to a long ground rod under ground. I would not be cutting that line, that would leave the whole house ungrounded.
Old 10-18-2012, 10:19 AM   #3
joed's Avatar
Rewards Points: 12,008
It could also go into the footing as a Ufer ground. There may not be any rods.
Dig around it. Do not cut the wire.
Old 10-18-2012, 10:59 AM   #4
123pugsy's Avatar
Rewards Points: 740
Thanks.
I can dig to the left of it. I added a pic that I had forgot earlier.
About 7' on the left is a water pipe coming in. I would imagine they shoot straight out of the house without doing any weird loops under the floor?
I guess I will make my hole on the left wall between the water in and away from the wire.
Old 10-18-2012, 07:55 PM   #5
Concrete & Masonry
Rewards Points: 530
Odds are the ground rod is right under the floor, and you'll likely damage the ground wire taking that section out. I'd check to see if it's the only ground wire and have a plan to repair the ground if you do decide to take that section out.
BTW, I'd be surprised to hear how wide you find the footings to be. I'm accustomed to seeing them at least 20" wide here, and would be surprised if they're only 16" wide, as you mentioned in an earlier thread........
Good Luck.
jomama45 is offline   Reply With Quote
Old 10-19-2012, 05:25 AM   #6
123pugsy's Avatar
Rewards Points: 740
I dug the hole on the wall to the left. There was no ground rod where I dug so I'm all set to go. The engineer is coming by this morning at 9 AM.
I did find the footing to extend about 4" beyond the 10'' block on one hole and about 4-1/2''-5'' on the other hole. I had dug down to the footing on the outside years ago when I had talked to an engineer about adding a second floor but only using siding. I remember measuring 3'' sticking out on the outside of the block. He assured me at the time 16'' footing with 10'' block was sufficient for the addition.
Someone had asked on another thread if the footing was sized OK and I answered it was but it got me thinking and I realized I had the green light to do the addition using siding, not brick veneer.
I'm thinking its probably about 18'' but not exactly centered.
We'll see what the results are shortly.
Thanks for the input everyone.
Old 10-19-2012, 10:13 AM   #7
123pugsy's Avatar
Rewards Points: 740
Everything checked out fine.
4000PSF.
16" footing is fine.
The Following User Says Thank You to 123pugsy For This Useful Post:
jomama45 (10-19-2012)
Replacing two wire dupex to duplex with ground. northern60 Electrical 10 07-09-2012 12:44 PM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 03:54 PM
Gfci receptacles wire continuity test Hialeahn Electrical 4 03-05-2010 07:52 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
Ground Wire Problem ScubaRaven Electrical 11 06-08-2006 03:32 PM
