Soffit Vs. Screened Open Eave - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-16-2011, 07:19 PM   #1
Soffit vs. Screened open eave
I was installing mesh on the open eves on my hip roof garage and I started wondering if there were any advantages to using prefab soffits instead of screening the open eves?
Section I've already screened:
shadetree is offline   Reply With Quote
Old 10-16-2011, 11:46 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,976
The bigger question is.....who did your roof nailing? Unless you like the look of nails sticking through....I don't think you have much choice. I would look into vinyl soffet with intergral vents.
ddawg16 is online now   Reply With Quote
Old 10-17-2011, 12:07 AM   #3
Rewards Points: 1,092
Don't you typically use nails that ALMOST stick through, so as to maximize their holding power? I am under the impression that nails that stick through are actually easier to pull out than those that almost stick out. No? thanks. j
Old 10-18-2011, 01:05 AM   #4
Don't mind the look of exposed nails, you can barely see them from the ground as this roof is on the 2nd story. I nailed on the new shingles with 1 1/4" nails and was under the impression that nails are supposed to go though the plywood sheathing? "The National Roofing Contractors Association and the Asphalt Roofing Manufacturers Association both suggest that the roofing nails should be long enough to penetrate the roof deck 3/4", or go completely through plywood or OSB type decking." http://www.roofhelp.com/roofingnailchart.htm http://roofgenius.com/roof-nail-size.asp
See any issues with how I'm installing the mesh screening?
Old 10-18-2011, 06:04 AM   #5
kwikfishron's Avatar
Rewards Points: 824
Installing bird blocks would be more effective (long term) and esthetically pleasing than what you’re doing.
kwikfishron is offline   Reply With Quote
to soffit or not to soffit timbo59 Building & Construction 18 08-12-2010 04:07 PM
Dropped soffit over shower? StevePax Remodeling 2 12-24-2009 11:24 AM
Vinyl soffit and fascia msyv Building & Construction 7 09-13-2009 10:21 PM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 04-30-2007 11:14 PM
Soffit installation question milano Roofing/Siding 4 02-04-2006 10:13 PM
