Old 07-01-2012, 01:17 AM   #1
Soffit Vents? New Siding Project
I am in the process of installing new vinyl siding. My existing soffit is wood with cut in vents every 6 feet or so. They are covered with metal vent covers that insect screens on the back side.
The question I have is should the vent covers be taken off prior to placing vented soffit under them?
jimsflies is offline   Reply With Quote
Old 07-01-2012, 09:08 AM   #2
AHH, SPANS!!!
I would recommend pulling entire old soffit down for for maximum ventilation in the new soffit when put back up.
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
joecaption (07-01-2012)
Old 07-01-2012, 10:02 AM   #3
Agreed, that would give you way more venting and once the vinyl goes up the old wood that's up there will be useless.
Old 07-04-2012, 01:43 PM   #4
Thanks guys.
Vinyl Perf Soffit over Wood - No Vents nickelshine Roofing 18 05-29-2012 10:12 AM
Removing Insulation from Soffit Vents cpfoutz Roofing 18 01-03-2012 10:35 AM
Do I need to replace soffit vents?? And other roofing questions. kennykenny Roofing 5 04-17-2011 10:22 AM
Soffit Vents Sammy Building & Construction 9 07-07-2008 07:31 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
