Soffit Or Siding? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-27-2011, 11:27 PM   #1
Rewards Points: 154
soffit or siding?
what would you do first and why?
aluminum soffit or vinyl siding?
awdblazer is offline   Reply With Quote
Old 09-28-2011, 12:15 AM   #2
Rewards Points: 558
Vinyl siding first and then finish the soffit because that’s how I do it others might do it differently.
epson is offline   Reply With Quote
Old 09-28-2011, 05:34 AM   #3
Rewards Points: 2,238
We've done it both ways (over the years - 30 to 35).
Now we'll, usually run the siding up - do the soffit - end the
siding in "J" channel w/ finish trim (UT)/Double UT.....
It's more complex ("jumping through hoops") to put the soffit "J"
on top of vinyl siding - correctly.
rossfingal
rossfingal is offline   Reply With Quote
Old 09-28-2011, 09:17 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
ive done it both ways. 98% of the homes i install siding on are reno's that we do start to finish, once we have the house weather tight and the fascia board is on we snap the lines for the f channel that takes the sofft, at that point we take measurements for the soffit. one guy starts cutting a pile of soffit then he installs it while the rest of us work our way up the wall.
the advantage of putting the soffit up first is to keep birds out of the attic space, they can fly up into the house if the eaves are wide open
woodworkbykirk is offline   Reply With Quote
Old 09-29-2011, 07:36 AM   #5
Rewards Points: 154
anyone have pics of this?
Old 09-29-2011, 07:46 AM   #6
Rewards Points: 562
on the little I have done,,,found it easier to run siding up, then you can vary soffit slightly to pick best spot. first one it came out exactly at the hardest spot,
Gable ends soffit f holder goes first then siding undersill ,,,then side right up to it
4just1don is offline   Reply With Quote
Old 09-29-2011, 07:49 AM   #7
kwikfishron's Avatar
Rewards Points: 86
You want to be sure the wb of the siding runs up past the soffit.
I prep the entire wall which includes running the soffit. Install the corners which butt into the soffit then start siding.
kwikfishron is online now   Reply With Quote
Old 09-29-2011, 11:18 PM   #8
Rewards Points: 154
what is wb???
Old 09-30-2011, 06:53 AM   #9
Rewards Points: 86
Originally Posted by awdblazer View Post
what is wb???
Weather Barrier.
The Felt or Tyvek etc. behind the siding.
vinyl Siding / Soffit Question J S Machine Building & Construction 42 04-18-2011 11:11 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 08:47 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
