Old 01-23-2008, 07:32 AM   #1
Soffit Running Thru Bathroom / Dropped Ceiling
I have a situation where water and gas lines as well as HVAC run thru my basement bathroom. I confirmed that my neighbors bathroom has a much lower ceiling than the other rooms to conceal the duct work. My question is, do I frame a soffit around this first to be able to attach my wall studs (they won't be able to go all the way up to the ceiling)? How do I extend the soffit all the way across the bathroom (probably another 4 feet)? Do I build one really wide soffit and then install bracing in the middle of the room to support the ceiling? The soffit area on the left is in an unfinished area but on the right side is in the middle of the bathroom.
xlr8tn is offline   Reply With Quote
Old 01-23-2008, 07:33 AM   #2
Oh...one other thing. I will be installing drywall and not the ceiling tiles.
Old 01-23-2008, 05:57 PM   #3
If i understand you right, you need a wall under the heat vent so you can't go all the way to the floor joist for your top plate? And you will be lowering the whole ceiling in the bathroom to go under the pipes and duct? build the wall first and then tie your new ceiling into the wall by running the ceilingframing on top of the wall and it will brace the wall.
ponch37300 is offline   Reply With Quote
Old 01-23-2008, 07:37 PM   #4
Exactly. What I was thinking about doing was building the left side of the soffit. Then, instead of having 2X4's spanning just the ductwork, it would span the entire bathroom and tie into a wall that will go all the way up to the ceiling. I was then going to extend hangers (2x4's) from the ceiling joists down to these 2x4's to keep the bathroom ceiling from sagging.
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 07:07 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Drop ceiling in basement bathroom handyflyer Remodeling 23 05-26-2009 10:12 PM
excessive moisture on bathroom ceiling Den69RS96 General Discussion 8 01-14-2008 09:37 AM
Running wire to a Ceiling Speaker (in vaulted ceiling) rgmetro Electrical 1 01-09-2008 11:27 AM
