Soffit Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-16-2010, 09:37 AM   #1
Soffit question
I am installing new vinyl soffits. I started to remove the old aluminum soffits that were not ventilated and covered original unventilated plywood soffits.
Should I take down the plywood soffits before I install the new soffits. The plywood has peeling paint and it appears to have little mold stains in places? Is it better to leave it and not deal with the mess of the peeling paint and cover it up with a new soffit. There is about 120" linear of 24" soffit. Thank You
teachtech is offline   Reply With Quote
Old 06-16-2010, 10:43 AM   #2
kwikfishron's Avatar
Rewards Points: 576
Yes, take down the plywood under the eves. You should have vented soffit at the eves.
kwikfishron is offline   Reply With Quote
Old 06-19-2010, 01:45 PM   #3
Exterior Resources, Inc.
ExteriorRes's Avatar
Taking down the plywood is an option but requires a lot of work. You also can cut holes in the plywood for ventilation and then install you soffit over the pllywood.
ExteriorRes is offline   Reply With Quote
Old 06-19-2010, 03:55 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
i like to pull the ply too,but instead of holes id prefer a continuous slot cut the entire length jmo
Tom Struble is offline   Reply With Quote
angled soffit headache Roofing/Siding 6 08-12-2015 01:19 PM
Question about replacing fascia and soffit paneling creamaster Carpentry 2 03-31-2010 09:01 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Installing Soffit and Facia??? Vikeologist Roofing/Siding 3 11-15-2006 05:01 PM
Question re: fiber-cement soffit material MichaelinOmaha Carpentry 4 10-12-2006 07:30 PM
