Soffit Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-30-2013, 10:27 AM   #1
soffit question
Hello,
When you have your end gable soffit j channel that holds in the soffit against the gable wall and lets say you want to add vinyl siding or vinyl shake siding underneath for the end gable wall. Below the soffit J channel do you just "but up" another piece of j channel for the siding or should you have a piece of flashing between the two pieces of j channel? Reason I am asking is because if you have the two pieces of j channel up against each other wouldn't that be a spot for water to get in?
markharmon is offline   Reply With Quote
Soffit question andybeck Building & Construction 6 07-10-2012 12:21 AM
Soffit Installation question nlambert Remodeling 8 04-21-2012 08:46 PM
Question about replacing fascia and soffit paneling creamaster Carpentry 2 03-31-2010 10:01 PM
Installing Soffit and Facia??? Vikeologist Roofing/Siding 3 11-15-2006 06:01 PM
Question re: fiber-cement soffit material MichaelinOmaha Carpentry 4 10-12-2006 08:30 PM
