Soffit Length - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-01-2010, 08:42 PM   #1
Soffit Length
I need to install soffit material under my 14' 9" porch. Does anyone make soffit material (D5 - White) in lengths greater than 12'? The house is in SW Louisiana.
Lyndon is offline   Reply With Quote
Old 06-01-2010, 10:46 PM   #2
If so I havn't seen it at a big box store. We redid our soffits recently and went with 8 foot lengths. We ripped down 4'x8' sheets since I needed more than the 12/14" inch width offered.
posylane is offline   Reply With Quote
Old 06-01-2010, 11:36 PM   #3
Lightbulb
Is the porch greater than 12' both ways? If not you can put batting strips across the joists (opposite direction) and run soffit material the shorter way.
Nailer is offline   Reply With Quote
The Following User Says Thank You to Nailer For This Useful Post:
Willie T (06-06-2010)
Old 06-06-2010, 04:09 PM   #4
The porch is 14' 9" x 27'.
Old 06-06-2010, 04:13 PM   #5
Old School
Willie T's Avatar
This is the way it's really made to be run.
Willie T
Old 06-06-2010, 04:17 PM   #6
I was hoping that I could find a manufacturer that made 15' soffit material so that I would not have an H Channel running down the middle of my porch.
Old 06-06-2010, 05:35 PM   #7
kwikfishron's Avatar
Rewards Points: 586
12’ is as long as I’ve ever seen it and I’ve done a lot of Vinyl using many different brands.
Since you don’t want to lap the stuff, your only options are to use a double channel and split is down the middle one way or into three sections the other way. A lot of waste, unless your doing the eaves also and can utilize those pieces there.
Or maybe get creative with a different color for a perimeter border so the 12’ stuff will work down the middle.
kwikfishron is offline   Reply With Quote
Old 06-06-2010, 05:51 PM   #8
Thanks everyone for the replies. Especially Kwikfishron - you've given me a couple of very unique thoughts!
Tags
eaves , facsia , fascia , soffit
Basement Fireblocking within HVAC Soffit ssmith147 Building & Construction 3 12-31-2009 06:36 AM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 09:15 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 04-30-2007 11:14 PM
