Soffit In Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-18-2007, 07:40 AM   #1
Question
soffit in basement
Hey gang!
When building a soffit, is it necessary to cover the framing of the soffit with OSB before drywall??
Thanks for any help!
DIY4EVER is offline   Reply With Quote
Old 06-18-2007, 07:49 AM   #2
RippySkippy's Avatar
nope, only if you suspect that it's not built strong enough or if your trying to span a distance that exceeds what the drywall will span.
RippySkippy is offline   Reply With Quote
Old 06-18-2007, 09:05 AM   #3
my answer is also no and
I also suspect the "only if" condition is really required.... as the support is by the frame, the drywall is only for cosmetic reason. so as long as you have a strong frame which can be achieved by a million ways... osb board is just one option and is not the only option ....
KUIPORNG is offline   Reply With Quote
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 09:55 PM
Framing a Wall with a Soffit on Top sethr Building & Construction 2 05-21-2007 08:14 AM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 04-30-2007 11:14 PM
Basement Soffit Advice 5thQuarter Remodeling 1 02-14-2007 12:37 PM
