So I've Decided That I Need To Jack Up The Floor... - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-07-2012, 10:43 AM   #16
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Okay. I don't think the cribbing will help me here, since I have probably less than 18" between the beam and the dirt. Would it be easier to use a premade pier block?
I might buy 2 or 3 of those 20T jacks in case I need to re-position something.
I'm assuming a steel plate between the jacking head and the beam is the best option because a piece of lumber will probably split, crack and deteriorate rather quickly, as it doesn't have the compressive strength needed for that application?
I probably won't even need a post between the beam and the jack if i can easily elevate the jack 6" off the dirt.
As for the amount of space, I dont think it will be so bad. 4x10 beams (i think) so in between the beams, i have a good 24" of crawl. That's a lot for me just as long as nothing comes down on me. (not likely considering the amount of the floor i need to move.)
Journeyman Plumber
Old 12-07-2012, 07:44 PM   #17
DIY staff
Rewards Points: 7,174
You are only lifting a short distance--and if something fails--the house will drop back only an inch or so---
Se if you can find a short section of rail road tie or other heavy timber---I don't trust concrete blocks---they can crack to easily---but once again--the worst that could happen is the house settles back an inch or so---
Old 12-07-2012, 08:11 PM   #18
Doing it myself
Alan's Avatar
Thanks Mike. I bet my dad has a chunk of railroad tie around somewhere.
Journeyman Plumber
Another case of shaky floor djenka2 Flooring 2 11-15-2012 04:17 PM
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
How to repair a concrete floor we just had repaired! timbo59 Flooring 11 01-04-2012 07:15 PM
Floor damage from a 2nd floor bathroom toilet leak Tamber Plumbing 3 05-03-2011 12:10 AM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 06:42 AM
